07-02-2022, 12:06 AM | #111 |
Rep 50
We know..under the flag of Brazil it reads "'22 Chalk Gray Porsche C2S". It's moving that you defend every BMW with such determination...with your regal ass on that gray and ugly thing. |
MadBimmeRad7122.50 |
07-02-2022, 12:23 AM | #112 | ||
Law Enforcer
25168
Rep 22,296
Drives: '22 Chalk Gray Porsche C2S
I think BMW balanced out the need to provide a better overall car than the outgoing model (…which objectively they accomplished; weight and personal opinion(s) about the aesthetics notwithstanding) while keeping overall costs reasonable. They brought a lot of positives to the table (…e.g. carbon fiber buckets, for example) for not much more expense than the prior model. It all depends on your vantage point I suppose. If you're looking for a reason to be mad at the company, look no further than rear brakes and hood lines. If you're reasonable in your assessments (…speaking generally, not directed at you personally), it's not hard to see that BMW brought a more premium product to the masses than what we got with the F8X. Make no mistake, I loved my F8X's just as much as any ///M car I owned prior, but I do feel the G8X is a step above the outgoing car. Quote:
07-02-2022, 01:08 AM | #113 | |
Rep 1,477
Drives: BMW M2
We are talking about rear calipers on a street car, since you are so expert you should know what impact this has on performance (nearly zero), the advantage of a multi-piston caliper at the rear is almost irrelevant and it is an unnecessary complication for a street car combined with the e-parking brake (this is the reason, just get informed before you talk randomly). Definitely not something to worry about. It's funny to read about cost cutting, Bmw could have used more expensive calipers (since they exist) and passed the price onto the finished product and thus onto the customer, but the benefit would have been irrelevant and I thank Bmw for saving me this unnecessary cost (well, in case I had it). There are much higher performance, heavier and more expensive cars than any Bmw with floating rear calipers, and they brake perfectly. I have no idea about the final specs of this CSL (I don't even read all the speculation these days, I only trust the official documents that I haven't seen yet), but it is too early to judge. You only have to drive a G8x to realize how much better it brakes than the F8x's multi-piston rear brake; judging braking performance by the number of pistons in the rear is like measuring manhood by the inches of your tool. Definitely forum bullshit. Most people wouldn't even know they have a floating caliper at the rear if someone didn't tell them. |
Sedan_Clan25168.00 |
07-02-2022, 01:20 AM | #114 | |
Rep 1,477
Drives: BMW M2
Bmw figured out where to increase braking (at the front, with a better caliper and wider rotors) and where to use a simpler solution (at the rear) without penalizing performance once it switched to electronic parking brake. They introduced the floating rear caliper back in 2011 with the F10 (first M car with e-brake) and no one complained, while it started to be a huge problem with the G8x for unknown reasons. It's a win-win: we have a car with better braking performance, lower costs, less unsprung mass, and even better aesthetics (just compare the rear offset of the F8x and G8x). |
07-02-2022, 01:27 AM | #115 |
Rep 2,700
It works but can't absorb as much heat obviously. Don't really care it looks smaller, my ego doesn't neither.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
07-02-2022, 01:28 AM | #116 | |
Rep 1,477
Drives: BMW M2
They merely choose which products to use from those offered by suppliers on the market (Brembo, in this case). Brembo (not Bmw) produces both more expensive and higher performance solutions (multi-piston rear calipers with e-brake integrated) for exotic supercars, and simpler and cheaper solutions for street cars (floating single pot caliper with e-brake). They could have chosen the more expensive solution and I'm pretty sure Brembo would have been more than happy to sell them, but it probably wouldn't have been worth it considering the intended use, that's all. |
07-02-2022, 01:39 AM | #117 | |
________
4160
Rep 2,301
07-02-2022, 01:57 AM | #118 |
Rep 1,477
Drives: BMW M2
Of course, they don't do charity. But did we lose anything? I'd say no.
The only M-car with a multi-piston rear caliper was the F8x, which braked like crap just like its single-piston rear caliper predecessors. The G8x won't go down in history for its braking (the grille steals the show), but the overall braking performance is a step up from its predecessor, and that's good enough for me. Too bad about the aesthetics of that tiny caliper, but whatever. |
Sedan_Clan25168.00 ________4160.00 |
07-02-2022, 02:11 AM | #119 | |
Law Enforcer
25168
Rep 22,296
I think you're also spot-on with reference to your other point in bold. We lost nothing. |
VIERsr2623.00 Tambohamilton3059.50 |
07-02-2022, 05:55 AM | #120 |
Rep 1,437
Floating rear calipers simplify the cost and packaging when combined with the parking brake. For street use you won't notice the difference, on my race car it makes a second a lap difference (apparently ;-)) and fade is better. It also can look look ugly - both ways |
07-02-2022, 11:49 AM | #121 | |
Rep 151
07-02-2022, 12:47 PM | #123 | |
Rep 2,305
G series cars have wider (by 20mm) and newer model tires that simply have more grip than the F series M Cars. The brakes on the F generation cars are just better. The difference is initial braking vs sustained braking. Swap the tires and I would wager the F car will outperform the G car in both initial and sustained braking.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
3RDSECTOR486.50 MadBimmeRad7122.50 |
07-02-2022, 02:36 PM | #124 |
Law Enforcer
25168
Rep 22,296
We can agree to disagree. Most things complained about on the forum are not concerns of the average buyer. If you asked the average person about the Hofmeister kink, they wouldn't even know what you're talking about (…let alone its General Motors origins).
xlover2198.50 MadBimmeRad7122.50 |
07-02-2022, 02:43 PM | #125 | |
Rep 1,477
Drives: BMW M2
Front calipers: 2-pieces 4 pot / 380x30mm vs monoblock 6 pot / 380x36mm Rear calipers: 2 pieces 2 pot / vs floating single pot, same rotors The brakes on the G80 are clearly better. |
Sedan_Clan25168.00 MadBimmeRad7122.50 |
07-02-2022, 03:43 PM | #126 | ||
Law Enforcer
25168
Rep 22,296
07-04-2022, 11:10 AM | #127 |
Rep 111
If it would have a cooler motor than the S58, would have been awesome.
Squeeze a s65b44 in it or a s85 or s62.... that's real homage!
Current:
///More Ms than friends at this point in my life and I am ok with it. Currently own all 7 gens of the ///M3 = life complete |
07-04-2022, 01:45 PM | #128 |
#savethemanuals
2435
Rep 1,970
If they have this manual transmission, why not do a special run for for the 4-door fans on the G80. Maybe a US spec CS that is not an automatic? Seems like a lot of development cost to just use on one car.
07-05-2022, 11:37 AM | #129 |
Starry_Angel
347
Rep 168
Are we even gonna get a LCI for 4er?
Be a girl with nature, be a lady with class, and a bitch with attitude.
07-05-2022, 11:47 PM | #130 | |
Rep 4,008
Drives: M235i, 420i, and now the M2 CS
Afterall, that's one reason this car is only coming in manual transmission.
M2CS,
The second coming of ///M! |
TractionControlDelete4599.50 |
07-06-2022, 05:25 AM | #131 |
Rep 4,001
I miss the times when a bmw special model was truly just that, special. I guess I'm getting old lol
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
07-06-2022, 09:53 AM | #132 |
Rep 230
Im under impression this is just a body kit for a 4 series with some glorified name and rediculous price tag.
e36->f48->....
