05-10-2020, 03:58 PM | #23 | ||
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
05-20-2020, 03:22 PM | #24 | |
Rep 142
Drives: 2016 BMW X5M & 2018 JLUR
Current: 2016 X5 ///M Donington/Mugello Red
Previous: 2010 X5 ///M, 2006 X5 4.4i & 2003 X5 3.0i "BMW El Placer de Conducir" |
05-20-2020, 04:05 PM | #25 | |
Rep 1,025
So @Chile1, did you get the fog lights working successfully? Yes, mine has those codes too because of the Euro switch. It doesn't affect the operation or function of the lights, however the 'ghost codes' will always remain.
05-20-2020, 04:16 PM | #26 |
Rep 142
that's the question i was hoping you could answer which you did. So then regardless of the codes you program, the "ghost codes" will always remain.
05-20-2020, 04:18 PM | #27 | ||
Rep 1,025
09-01-2020, 12:12 AM | #28 |
Rep 35
Hello guys,
I am joining into this subject. I have also bought a European light switch containing the rear fog button. It was successfully replaced and without any coding seems to work on US spec tail lights. The problem seems to me that the inner turn signal lights up instead of the regular rear fog lamp. I haven't done any coding but checked the REM which seems to be set to the right settings shared all over the forum: HTML Code:
REM -> Mapping_Nebelschlussl_L_output: nsl_l REM -> Mapping_Nebelschlussl_R_output: nsl_r FEM_BODY 3060 NSL_Verbaut: verbaut Here is example how it is currently. Rear fogs turned off rear fog lights turned On |
09-01-2020, 11:09 AM | #29 |
Rep 1,025
08-11-2021, 09:16 AM | #30 |
Meat Popcicle
10
Rep 18
When the Euro rear fog switch is installed and coded, does the "Brake Force" function of the tail lights still work when emergency braking when the fog switch is set to off?
12-13-2021, 09:55 PM | #32 |
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
did you get it done? If not hit me up, I'm in STL...
Chile143.00 |
03-28-2022, 01:42 AM | #33 | |
Rep 6
03-28-2022, 12:10 PM | #34 |
Rep 7,449
I’ve never pulled this trim before…but a quick look at the diagram for this section of the dash…lists #7 as the trim for the light switch…and #17 + #2 are the trim pieces that’s around the air vent:
EDIT: here’s the instructions from the TIS on removal of the switch unit and the surrounding trim pieces:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-28-2022 at 12:51 PM.. |
05-28-2023, 09:29 PM | #36 |
Rep 142
thank you for coding my X5M this afternoon for the Euro Fog lights!!
05-28-2023, 10:35 PM | #37 |
Rep 2,716
Drives: M3
Glad I could help out!!
Chile143.00 |
