05-22-2020, 12:49 AM | #1 |
Rep 735
Joyeauto Wireless Apple CarPlay Issue - No Sound
I had bought a used Joyeauto Wireless Apple CarPlay from a member on here a few months back. I actually only just discovered about 2 weeks ago that I can connect wirelessly. LOL
All of a sudden though, there's no sound. It's connected through Wifi and IDCORE Bluetooth and the interface is there but not sure what happened to the sound. When I connect the phone via USB, then I get sound and actually can use the Apple CarPlay interface for control like pause, next..etc.. But then sometimes the sound will stop. Is there something in the menu I need to check or could it be an issue with the unit or loose wire? |
05-22-2020, 10:02 AM | #2 | ||
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
05-22-2020, 10:32 AM | #3 | |
Rep 735
Also just realized that even the wired connection for the module doesn't have sound either. The USB connection I mentioned above is the car's USB port in the arm rest. Must be something wrong with the output from the module to the car's audio? |
05-22-2020, 10:59 AM | #4 | ||
Rep 1,025
05-22-2020, 11:03 AM | #5 |
Rep 735
A had a shop install the module so not sure where to look for that. Would it be behind the dash or accessible somewhere from underneath the glove box or something?
05-22-2020, 11:05 AM | #6 | |
Rep 1,025
It's the main/sub plug behind the HU. If you paid for installation, maybe let the shop check for you.
05-22-2020, 11:15 AM | #7 |
Rep 735
05-22-2020, 06:06 PM | #8 |
Rep 735
Figured it out. User error! :P Which I'm glad it was as it means it was an easy fix.
I had to select Aux input under Multimedia. I think it was defaulted there but I probably accidentally changed it a few days ago and the audio stopped. I opened a chat with Joyeauto and that was the first thing they asked about. Thanks for your help nonetheless Kraftwerk AG. |
Kraftwerk AG460.00 |
