05-24-2020, 10:57 PM | #1 |
tends to get irritable
202
Rep 798
Sequential mirror led blinkers
I didn't see much in the way of pictures when I briefly searched although I think Maverik259 has a DIY somewhere so I figured I would take a few pics for others searching. Unfortunately I thought about that a little late so the pics are only showing reassembly, where screws go, clips to release, etc. Sorry ! At least there is some reference.
The simple and quick way- Tilt mirror glass upward, pry from the bottom and pop it off, remove heat and/or autodim wiring and set it aside With a rigid pry tool (or flathead) release the two tabs inside for the cap to come off Remove all the screws with a T10 and you can then pop the frame off. Pivoting the mirror away makes this a little easier Unplug the factory light remove the remaining screws (3) and then tilt the assembly in (towards the door) and you can swivel to remove the bottom section which contains the light. Remove one screw and release one tab/clip to pop the light off. Pay attention to the tab closest to hinge side of the light as it inserts into a groove where one of the screw spots are to slide it in straight. Reverse order to reassemble. Any questions, feel free to ask !
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile |
05-25-2020, 01:31 AM | #3 |
202
Rep 798
I have no issues with their brightness at all. I've done a few sets and haven't heard of any issues on those either.
05-25-2020, 03:35 AM | #4 |
Rep 26
05-25-2020, 06:18 PM | #5 |
202
Rep 798
In direct sunlight: https://drive.google.com/drive/folde...EZ?usp=sharing
05-30-2020, 12:41 PM | #6 |
1150
Rep 2,426
Does look too bad actually.
05-30-2020, 12:49 PM | #7 | |
Rep 289
Might take it off and see if I can get the moisture dried out inside the house...
Eibach Pro Kit & Lowering Links, RC GTS Black 2014 M135i 3dr |
05-31-2020, 10:27 PM | #9 |
Rep 885
06-01-2020, 08:50 PM | #11 |
Rep 536
06-02-2020, 09:54 AM | #15 |
202
Rep 798
These are the exact ones that I did: https://www.aliexpress.com/item/3297...27424c4df0nmx9
06-03-2020, 02:57 PM | #17 |
Rep 1,247
06-04-2020, 09:09 AM | #19 |
202
Rep 798
06-07-2020, 10:05 PM | #20 |
202
Rep 798
Added another video in a garage bay with the lights out:
https://drive.google.com/drive/folde...BJcl4mFkg24MEZ
06-08-2020, 09:56 PM | #22 |
202
Rep 798
Probably a little easier to view via YouTube-
