      04-15-2020, 05:38 PM   #1
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
PCs
What PC configs work best? Would an intel NUC like a Hades Canyon be up to the task?
      04-15-2020, 06:12 PM   #2
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
If you are talking a PC primarily being used for sim racing purposes you do not need anything special.
Go look at the system requirements for iRacing or Assetto Corsa and you will see that pretty much any computer from the last 5-10 years will work just fine.
I picked up a used PC (with an AMD A8-5500) for under $300 that I'm using and it's running Assetto Corsa with ease. That said, I'm not a gamer, so if you plan to use it for other gaming purposes don't bother listening to me
This post sent using 100% recycled electrons.
      04-15-2020, 09:45 PM   #3
Andrew
Moderator
Andrew's Avatar
425
Drives: E46 M3 / E92 M3
2003 BMW M3  [0.00]
2008 BMW M3  [0.00]
Check out https://pcpartpicker.com/ as they have custom builds documented. Seems like you can build a solid overall gaming rig for around $800 using the AMD Ryzen 5 CPU and a AMD RX 580 video card.
Check out these builds for under $800. https://pcpartpicker.com/builds/#X=0,80905&s=33
[Track] 03 AW/CIN 6MT E46 M3
[Street] 08 AW/FR 6MT E92 M3
[Tow/Overland] 23 Toyota Tundra HV TRD Off-Road
      04-15-2020, 10:04 PM   #4
jimbobiggens
jimbobiggens's Avatar
Drives: 2013 335i xDrive
A NUC mini PC is a good idea on paper but has heat issues. I7 processor + passive cooling + small space = trouble. We had three of them at work and had to remove all of them because of overheating and freezing the video output during Zoom presentations. They were the sixth generation that supposedly have a "fix" for overheating. I've got one on my desk, it makes a nice paperweight. The skull on top is a nice touch.
I'm not completely useless, I can be used as a bad example.
      04-16-2020, 03:04 PM   #5
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
What about a raspberry pi lol? I keed I keed.
      04-16-2020, 03:39 PM   #6
jimbobiggens
They work well for firewalls. Mine is running Ubuntu 18.04 server and works great. Less than a hundred dollars for a fully hardened and capable firewall is not bad. I wouldn't use it for a PC because the graphics are weak.
I have one of those Lenovo m720 Tiny small form factor desktops with I7 processor, 16 GB ram, 1TB M.2 SSD hard drive I use for a Windows deployment server. Works great, fast, stable. It's very similar to this:
https://www.ebay.com/itm/Lenovo-Thin...UAAOSwsEteZnzo
      04-16-2020, 05:17 PM   #7
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
I use untangle firewalls at home. So I’m guessing a high end integrated GPU is okay and you don’t really need a independent gpu for this type of gaming.
      04-16-2020, 06:04 PM   #8
jimbobiggens
Oh, fooey. I missed the part about using it strictly for sim racing. Yeah, pretty much anything with decent RX580-ish specs will work.
      04-26-2020, 02:27 PM   #9
detroitm2
detroitm2's Avatar
Drives: 2018 M2
2018 BMW M2  [0.00]
As long as you only do 1080p on a single monitor and/or don't mind dropping graphics settings down.
Im running an RTX 2080S and can hit 100fps or so on 3 x 1440p monitors with high/ultra settings in most titles. ACC takes the most graphics power, iRacing the least.
So YMMV depending on what your expectations are and setup.
2018 M2 - Daily Driver/Track Car
Motorcity BMWCCA Member
Instagram | YouTube
Search this Thread:
Advanced Search
