03-25-2016, 05:47 PM | #1 |
Rep 18,715
DIY: RaceChip Ultimate for F85/F86 X5M/X6M Installation Instruction
Guys,
As promised and great thanks to onfireX5 for the pictures and testings, here I present to you, the installation instruction for the RaceChip Ultimate. Feel free to ask me for any question. I attached the PDF file since it is easier or you can always find it on my website in the RaceChip Ultimate for F85/F86 X5M/X6M description. RGSport-F85_F86_RaceChip_Ultimate.pdf
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... Last edited by r33_RGSport; 10-02-2017 at 04:49 PM.. |
03-26-2016, 12:26 AM | #4 | |
Rep 18,715
Not any mechanic.
03-26-2016, 05:48 AM | #6 |
Rep 455
thanks. one thing I didn't see here that onfireX5 referred to was the ability to quickly revert back to stock. I've been in the airbox so far but not underneath, and the install instructions look easy. Is the reversion to stock simply swapping out the connectors again so that the RC is bypassed? With it installed as shown, zip ties etc., does one simply pull the airbox and then the connectors are reachable to swap?
2016 X5 M - Sapphire Black/Aragon Brown, IND Black front/side grilles/side markers 2014 C63, Klassen M52Rs, Eurocharged tune - Gone |
03-26-2016, 08:05 AM | #7 | |
Rep 18,715
03-26-2016, 08:07 AM | #8 | |
Rep 18,715
The sensors are visible once you remove the airbox, but you still need to reach in inside the engine bay to get into the sensor.
03-26-2016, 08:55 AM | #9 |
Rep 4,532
The bypass plug was a big selling point for me. The RC module is digital and should live as long as any other electrical component on the M. However, it's nice to know if I'm 1000 miles from home I can bypass it and revert back to pure stock in 60 seconds. Just slide the purple locking tab and install the bypass. Gtg.
04-10-2016, 06:55 PM | #10 |
Rep 91
So I have a quick question about the install that might be so obvious that it is also a stupid question: how do you disconnect the battery?
Under the hood there is simply a positive terminal to connect to, but not manufactured to actually disconnect. I think the battery is located in the rear, so do I access it there and pull the positive terminal on that end?
2024 BMW XM
2024 BMW M240i XDrive - Wife’s Car 2023 Ford Bronco Raptor, 2017 BMW 540i, 2016 BMW X5M, 2011 BMW M3, 2011 Carrera GTS, 2010 Panamera S, 2009 911 Carrera S, 2001 Boxster S - gone |
04-10-2016, 07:00 PM | #11 | |
Rep 18,715
I usually disconnect the negative. If you have 2 batteries, undo both of them.
04-10-2016, 07:40 PM | #12 |
Rep 91
Thanks Ben. I have a little 'project' that I'm getting set to complete tomorrow evening.
2024 BMW XM
04-10-2016, 07:42 PM | #13 |
Rep 18,715
Wish you luck.
04-11-2016, 05:19 AM | #14 |
Rep 5,066
I've never disconnected the battery on mine and I've changed installed and uninstalled a few times.
04-11-2016, 07:31 AM | #15 |
Rep 91
Thanks...probably don't need to disconnect, but also REALLY don't need to short anything out. Actually more concerned about getting the engine bay to cool down enough to not get 3rd deg burns...it was still pretty damn hot 3-4 hours after getting back from a 30 min drive down the highway with the family yesterday (so wasn't pushing it at all).
2024 BMW XM
04-11-2016, 08:07 AM | #16 |
Rep 5,066
I can understand the concerns.. but again I've done it several times disconnecting the tune for car oil change services and MPPK tune installs at my local dealer. None of my other buddies that also have the RCU disconnect the battery as well. I guess it doesn't hurt to be extra careful, but just saying it isn't necessary.
04-11-2016, 09:14 AM | #17 |
Rep 4,532
Alternative I use (dis batt is best), is turn engine off, unlock hood and raise, lock all doors, place fob 50ft from car, wait 10 minutes. Computer goes to sleep. Good to go.
04-11-2016, 09:23 AM | #18 | |
Rep 455
04-11-2016, 09:26 AM | #19 |
Rep 91
Yep, just touched the engine and airbox cover yesterday afternoon and decided I was going to have to do this another time. Thinking I'll leave the office early and finish the day from home, just so I can do this around 6P or so.
2024 BMW XM
04-11-2016, 09:36 AM | #20 |
Rep 5,066
Right, I failed to comment that I do let my X5 go to sleep before disconnecting and reinstalling.
04-11-2016, 11:14 AM | #21 |
Rep 944
I did not disconnect my battery but followed the included instructions in detail. Was concerned about the battery as I read other piggy instructions and they all stress disconnecting.
The overall install is pretty simple but accessing the sensors is a pain. Disconnecting the sensors was hard but reconnecting the RC was really challenging. So fully removing before next service will be hard |
