10-17-2020, 03:05 PM | #221 | |
Rep 417
ACID.
10-19-2020, 01:09 PM | #222 |
Rep 970
Just have the pads changed to Ceramics, and be done with it.
10-21-2020, 03:30 PM | #223 | |
Rep 592
Nothing more embarrassing than pulling up at the light and you're the one squealing. All kinds of things is running through people heads at that moment, including yours. As your fellow New Yorker, do like the last guy said and change pads to ceramic and be done with it. Squeal free. Stopping power tad bit less and that jerky brake bite is less but adapt your driving habits and you'll adjust. Not to mention. No more brake dust. And 80% of us are using PowerStop. Good luck. |
Slickrick2206.50 |
10-21-2020, 10:18 PM | #224 | ||
Rep 417
ACID.
10-21-2020, 11:17 PM | #225 | |
Rep 61
10-22-2020, 07:26 AM | #226 | |
222
Rep 374
POWER STOP Z23919B (Z23-919B) Brake Pad (rear) POWER STOP Z231738 (Z23-1738) Brake Pad (front) PAGID 355251731 Brake Pad Wear Sensor (2) PAGID 355251751 Brake Pad Wear Sensor (2) |
John Tanglewood1309.00 |
10-22-2020, 02:36 PM | #227 |
Rep 592
It all depends on how long you can stand the squeal. From my experience it seemed to squeal more in the winter, so. For the most part all who have changed they pads were because of the squeal and the dust. OEM Pads just had to go lol.
10-22-2020, 02:45 PM | #228 |
222
Rep 374
Cut and paste from my brake thread....
Alright, pads are on. Initial impressions after bedding in are positive. I honestly didn't have a lot of seat time on the stock pads as I've only had my car for a few weeks, but I think these are equivalent in pedal feel. MAYBE a tad less initial bite, but that may be just because of what others have said here making me biased. Anyway, not a peep out of them so far which was amazing in the stop and go traffic on the way home and pulling into my garage like a ninja. Obviously need to get some miles on them to see if the squeal stays away, but I'm ecstatic so far! |
10-23-2020, 08:26 AM | #229 |
Rep 970
Good to see a satisfied customer, I'm just waiting for the old rotors and pads to wear out, so I can install all new hardware on my X5M.
10-23-2020, 11:33 AM | #230 |
Rep 631
10-31-2020, 02:45 PM | #232 | ||
451
Rep 348
2016 BMW X5M F85 | 2019 - Present
2015 BMW X5 F15 5.0i m-sport | 2016-2019 2001 BMW X5 3.0i Sport | 2005 - 2008 |
11-01-2020, 07:44 AM | #233 | |
222
Rep 374
Note: You only need one sensor per axle. One of each part number I listed. Can't speak to using the OEM sensors, but they are cheap, so I'd replace them. |
11-01-2020, 07:53 AM | #234 | ||
451
Rep 348
12-06-2020, 07:00 AM | #235 |
451
Rep 348
Finally got around to doing the brakes myself. Started with the passenger side - took longer than I wanted. However, the driver side was a breeze after figuring out the correct process.
Also, I was able to do a decent bedding process. 80-20 8 times without coming to a complete stop. It's been about 2 weeks and I'm very happy I did this! Dust is barely noticeable and squealing GONE.....
Slickrick2206.50 |
12-13-2020, 09:33 PM | #236 | |
Rep 196
Did you use BMW recommended Plastilube on the front pads or something else? Thanks. |
12-13-2020, 10:18 PM | #237 | ||
451
Rep 348
09 - Bracing Spring 06 - Guide Pins I used the Brake-Pad paste provided by PowerStop.
12-14-2020, 08:25 PM | #238 | |
BETTO
30
Rep 130
Thanks |
12-14-2020, 08:34 PM | #239 | ||
451
Rep 348
Power Stop Z23-1738,Z23 Daily Driver Front Carbon Fiber ... https://www.amazon.com/dp/B086M7J4DV...UTF8&psc=1 You need only two - 1 for each axle Hella Pagid 355251731 Disc Brake Pad Wear Sensor An elec... https://www.amazon.com/dp/B01IP984EG...UTF8&psc=1
GODZLLA13.00 |
12-15-2020, 06:29 AM | #240 | |
Rep 417
ACID.
12-21-2020, 11:33 AM | #241 | |
Rep 37
03-31-2021, 08:04 PM | #242 | |
Rep 29
Just to confirm, these brakes will fit a F86, correct? |
