05-23-2020, 01:54 PM | #1 |
Rep 50
Problems to look after on pre-owned X5/X6M
Hi,
Looking into getting either a 2016 X5 M 26k kms (16k mi) or a 2016 X6 M 21k kms (13k mi). Can you guide in which problems I could find or changes you got down the line until aprox 50k kms or 35k mi Thanks! |
05-23-2020, 07:47 PM | #4 |
Rep 84
I had my sway bar replaced under warranty at 19k miles due to leaking. But other than that no issues. $3,600 repair to BMW.
2016 X6M - Minera Whitel Metallic | Akrapovic Exhuast - Dinan Intake - Dinan S2
05-23-2020, 09:18 PM | #5 |
Rep 907
66,000 miles.... No issues... Routine and preventative maint and the usual recalls...
yasavguy39.50 DgjoX6M2016455.00 |
05-26-2020, 05:53 PM | #6 |
Rep 1,152
Some issues my X5M had.
Rear differential fluid leak replaced and covered by warranty at 25K miles ($5000 or so per dealership). Steering column replaced under warranty at 30K mi (not sure how much it would cost out of pocket, but I'm sure it's at least $500). Rear air bags recently replaced at 35K mi - out of warranty ($700 parts/labor at indy shop - Dealership cost at least double that). Nothing "major"; but it's a BMW and expect issues to arise. |
05-26-2020, 09:08 PM | #7 | ||
Rep 50
Thanks! What year is your X6 M? |
05-26-2020, 09:32 PM | #8 |
Rep 1,152
05-26-2020, 11:35 PM | #9 |
528
Rep 2,822
Drives: X5M F85
05-30-2020, 12:18 PM | #10 |
Rep 900
2015 X6M 52k miles, done under warranty:
- Steering column - Driver door soft-lock - Bloody squeaky front brakes replaced multiple times - Front wheels chuttering noise when cornering Now that it's outta warranty, noticing right rear airbag leaks only when I repark the car, e.g. pull out of the garage and park in the drive way or vice versa. |
06-05-2020, 09:35 PM | #11 | |
Rep 1,061
Bobby_Drake388.50 musa421.50 |
06-07-2020, 08:08 PM | #12 |
Rep 944
2015 X5m
Replaced under warranty - front diff - rear air bags -complete set of brakes due to noise All happened around 50k miles. |
06-17-2020, 10:49 PM | #13 |
Rep 2,004
subscribing
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
10-20-2020, 12:06 PM | #14 |
Rep 223
Drives: F86 X6M // E53 X5 4.8is
My 2016 X6M has 36k miles and the sway bar also leaking, the dealer just replaced it under warranty. Wow, I didn't know it was a 3600 dollar job.
10-20-2020, 12:31 PM | #15 |
Rep 998
Nearing 60K and not one single issue thus far.
11-03-2020, 12:57 PM | #18 |
Rep 900
I replaced them myself with arnott bags - easy and now problem solved. Set me back around $350 but they have lifetime replacement warranty, so if they break again, I get new bags for free.
11-03-2020, 02:29 PM | #19 |
Rep 998
I am right around the corner at 60,000 miles, and luckily I have had a single issue. But keeping my fingers crossed. My X5M is going in for both front and rear differential flushes, transfer case flush and transmission flush next week.
11-03-2020, 03:09 PM | #20 |
Rep 1
I just purchased a 2017 X5M with 72,000 miles. I had a 3rd party inspection done and everything looked good. After driving it home, I immediately noticed an oil leak in my driveway and it turned out to be a leaking upper oil pan gasket. $3,400 estimate for repair as the front suspension has to be removed to access it. Fortunately I was able to get the Chevrolet dealership I bought the vehicle from to pay for the repair. I'm not able to get an extended warranty as the vehicle has a Stage 2 Dinan Package. Hopefully no more major issues going forward.
12-21-2021, 05:29 AM | #21 | |
151
Rep 301
Drives: 2017 BMW X5M
