06-16-2019, 08:59 AM | #4841 | |
Rep 29
My car is 2014 model, I don't know if there is any difference in the wiring from 2014-2016? |
06-19-2019, 12:08 AM | #4842 |
Rep 106
I previously successfully coded sports+ to my F10 via esys, but am now trying to accomplish the same to my 2015 F15.
If I follow the F10 instructions, it says to REPLACE 205 with 2TB. But from the instructions I've seen so far for F15, it only says to ADD 2TB. Is this correct? Or should I also be deleting something when coding/adding 2TB to the FA? Edit: nevermind, figured it by just trying (just add it). Got it working. Thanks Last edited by ManImCool; 06-19-2019 at 07:42 AM.. |
06-19-2019, 09:22 AM | #4843 |
Rep 106
Alright, new question. I've owned this F15 X5 for a little under a week now, and definitely noticed that the previous owner already did some of the codings I would have done myself.
But for the first time since owning, I tried BMW's navigation, and quickly noticed that the navigation (and cruise control) indicators were not showing up on the HUD. I don't know what the previous owner could have done to accidentally (or on purpose) code that out. Going to the HUD display options on iDrive clearly show "Navigation" as selected, yet no navigation shows on the HUD. The only items that display in the HUD are my speed and speed limit. Anyone have any idea how to fix this? Is there a specific ECU I can VO code to get everything back to default settings so get it working again? Earlier this morning, I added 2TB and VO coded BDC_Body, Kombi, and ICM, so those were already recently reverted to default. If it matters, I have the 6WB instrument panel. |
06-19-2019, 09:43 AM | #4844 | |
Rep 40,650
06-19-2019, 10:59 AM | #4845 | |
Rep 106
It's a bummer that in general, Nav can't show up on both HUD/Kombi. But I don't even get it on one of them! Like I said, I'm happy to hit the nuclear option and VO code mostly everything back to stock (but with 2TB added) and start over, but I'm (not) sure where to begin, and I'm confident the more experienced coders here can direct me in the right direction. Thanks! edit: typo. I'm NOT sure where to begin Last edited by ManImCool; 06-19-2019 at 11:26 AM.. |
06-19-2019, 11:07 AM | #4846 | |
Rep 40,650
06-19-2019, 11:15 AM | #4847 |
479
Rep 317
shawnsheridan Hey could I get a copy ESYS and launcher + PSdZdata? Looking to install into a newer laptop, and the version that i have i can't seem to do anything but VO coding due to missing token password for FDL.
Thanks |
06-19-2019, 11:28 AM | #4848 |
Rep 106
06-19-2019, 11:56 AM | #4849 |
Rep 40,650
There are no other ECU's affecting this function.
06-19-2019, 11:57 AM | #4850 |
Rep 40,650
PM sent.
06-19-2019, 05:21 PM | #4851 |
Rep 106
Well, unfortunately I VO coded both Kombi and HU_NBT, but there still isn't any navigation showing up on the HUD OR Kombi. Now what? Is it possible the requisite code was deleted out of FA? If so, what would that value be to look for?
06-19-2019, 05:35 PM | #4852 |
Rep 40,650
No. There is no Option Code for just Nav Display. Only relevant options are 610 HUD and 609 Nav Pro. Isn't car under warranty still? Get dealer to fix it.
06-20-2019, 07:29 AM | #4853 |
Rep 106
06-20-2019, 09:05 AM | #4854 |
Rep 40,650
Is 6WB original factory fitted or a retrofit?
06-20-2019, 09:37 AM | #4855 |
Rep 480
06-20-2019, 12:22 PM | #4856 |
Rep 106
I had just assumed it was a retrofit; I'll ask the dealership if they know. Is it something I can quickly determine by checking the VIN and the packages included? I don't recall seeing any option like that listed when reviewing it pre-purchase.
06-20-2019, 12:39 PM | #4857 |
Rep 40,650
Decode VIN and see if car has Option 6WB. If 6WB was retrofitted then VP Coding me not be enough, and you need additional FDL Coding.
06-20-2019, 01:13 PM | #4858 | |
Rep 106
PM'ing you my VIN if it can clear anything up. If it was retrofitted, do you know what I'll need to do re FDL coding? |
06-20-2019, 01:41 PM | #4859 | |
Rep 40,650
Make sure these are FDL Coded: HU_NBT => KOMBI_CIC = kombi_high HU_NBT => GUIDING_KOMBI_HUD = aktiv
06-20-2019, 04:36 PM | #4860 |
Rep 106
One other quick thing - I’m not sure where things went wrong because I’m pretty confident I correctly selected F025 during the initial E-Sys setup, but yesterday after VO coding Kombi/NBT, I noticed the funkktionen folders’ names were all blank except with a period “.”
I suspect it might have something to do with doing some VO coding earlier this week with my computer date set to January 2017, but more recently did VO coding with the actual date of 6/19/2019. Normally Esys won’t let me move past token creation unless the date has been set to 1/1/2017. But for whatever reason, it didn’t require me to do so yesterday, nor did I notice that it let me without changing. To fix this, is this a case of doing more computer date manipulation moving forward 4 days then backwards? If so, from which date - 1/1/2017, or 6/19/2019? In the alternative, I can just reinstall E-sys and select F25 again, but what would the steps be at that point? Repeating all the VO coding I did over the past week? If so, from what date? |
06-20-2019, 05:31 PM | #4861 | |
Rep 40,650
In your case with VO Coding, you would be bypassing E-Sys Launcher, so that is why nothing would be mapped. If you need mapping for FDL Coding, then use E-Sys Launcher.
06-20-2019, 05:38 PM | #4862 | |
Rep 106
Back to the above coding, GUIDING_KOMBI_HUD doesn't have nicht/activ as options. It is selected on "l6_kombi_hud" with the other option being "rueko_mit_hud." I then saw that KOMBI_CIC was already set to High. Thoughts? |
