10-12-2018, 07:08 PM | #1 |
N00B
94
Rep 210
BMW should put me on payroll... So many dealership visits and still having issues!!!! If anyone could help troubleshoot or has experienced similar issues, please chime in and I can pass the "deets" onto the dealer. I have been without my car for over a month now on parts being replaced and "diagnosing". I always use 93 and up at Costco and have never used fuel additives.
2014 X5 50i Parts replaced/brand new over the last 4 months;
Current Errors/Issue. (1 day after picking my car up from the dealership (Crankshaft vent hose/rubber boot were replaced) Check Engine Light Carly Diagnostics - Results Code:
Immobilizer System Fault Code: 80436A Fault Explanation: Auxiliary water pump: Short circuit to positive or open circuit Code:
Immobilizer System Fault Code: 8044D7 Fault Explanation: Interior light layering LIN: Number Layering slaves incorrect / Interior light layering FI-LIN 1: Number Layering slaves incorrect Code:
Engine/Motor Fault Code: 102005 Fault Explanation: Air filter, air mass meter signal deviation, coupling: inflow bad Code:
Engine/Motor Fault Code: 118101 Fault Explanation: Mixture control 2: mixture too lean
The owls are not what they seem!
10-13-2018, 01:39 AM | #2 |
Rep 1,170
Hello there first model year 50i owner! I also did 2 - 5. But man, that sounds like a lot more issues. Best of luck, the 50i is definitely high maintenance car
2014 X5 xDrive50i |
10-13-2018, 03:31 AM | #3 |
482
Rep 317
Well These two codes 102005 and 118101 seem to be correlating with each other as for faults, given that they've remove/replace intake hoses Id start checking for any improper installation of intake hose/seal after the MAF sensor, any air leak (vacuum leak) after MAF will cause incorrect fuel mixture and usually will trigger a lean condition.
Engine/Motor Fault Code: 102005 Fault Explanation: Air filter, air mass meter signal deviation, coupling: inflow bad Engine/Motor Fault Code: 118101 Fault Explanation: Mixture control 2: mixture too lean ------------------------------------------------------------------------------------ For this one check fuse #53, fuse box located in the trunk. Immobilizer System Fault Code: 8044D7 Fault Explanation: Interior light layering LIN: Number Layering slaves incorrect / Interior light layering FI-LIN 1: Number Layering slaves incorrect ------------------------------------------------------------------------------------ This one is the electric water pump for the turbo water intercooler, short circuit/open circuit means pump is not running, Since the dealer when rummaging thru that area, i check the the power plug to the pump and fuse (i dont know where that fuse is), before replacing as this part is kinda buried within front of the engine and lot of lines/hose need to be removed before extraction. Immobilizer System Fault Code: 80436A Fault Explanation: Auxiliary water pump: Short circuit to positive or open circuit |
10-13-2018, 09:15 AM | #4 | |
N00B
94
Rep 210
I purchased the overpriced Platinum warranty not too long ago to cover me and my only experience so far is 3 out of 3 separate dealerships milking me for unnecessary parts and half ass troubleshooting. I expect better service/work for a 115k car.
10-13-2018, 06:17 PM | #5 | |
Rep 1,170
I had coil issues that had to be replaced. I went four times to the dealership to get it addressed and got confusing troubleshooting (mass air flow sensor replacement (?), swapping (?) coils, etc). Went to an independent mechanic who knew his sh!t, right away said "bad coil." So I said replace it, and replace the rest. As easy as that. Of course, I'm out of warranty so keeping my fingers crossed I don't need an engine replacement or anything of that scale, but I already saved so much time and money already out of warranty because the dealership takes too long repairing and diagnosing the problem and forced me to find a more efficient route. No more loaners and phone tag (for now).
2014 X5 xDrive50i |
10-14-2018, 12:09 AM | #6 | ||
Rep 7,160
08-06-2020, 06:37 AM | #7 |
Rep 2
Sorry to revive an old thread, but wondering if this issue was resolved for the OP, and what the fix was. I am experiencing similar issues and hope to not have to replace everything on this list!
09-05-2020, 12:14 AM | #8 | ||
N00B
94
Rep 210
*Update, almost forgot to add... they said and documented that they replaced the auxiliary pump and I still have the error to this day.
