02-27-2022, 09:08 PM | #1 |
Rep 28
Hi All,
Been on various BMW forums for 15+ years and recently purchased a 2017 X5M. I purchased the car from Vroom and they have a 7-day return policy—I immediately brought the car to a trusted independent shop I work with here in DFW for a post purchase inspection. The car looked incredibly clean with the exception of the oil gasket crusher not being properly sealed during the last oil change, resulting in a slow leak. However; when my shop then performed an oil change, they saw copper in it… Vroom is offering to cover a portion of the rod bearing replacement (2500 on 4000 estimate…seem in line?) but my bigger concern is the premature failure and if there are other issues that will follow. There's no knocking or any other signs and my mechanic believes we caught it super early. Quick stats on the car - two owners, clean title, no accidents - 36,000 miles - spent 28,000 miles in SoCal and last 8k in San Antonio, Texas - rest of car looks great- engine runs well, no rust on underbody, no strange noises, etc. carfax is standard service stuff performed per BMW rec. Money aside, would this be a huge red flag to y'all? I've been looking for this spec and mileage for quite some time so I'm really hoping to find a resolution. That said, I don't want a money pit. I can return up until end of week.. I did buy an extended warranty but the 4k is not covered because it doesn't kick in until 90 days after ownership. In short- rod bearing failure caught early—fix, or run while I can? Thanks so much everyone! Sorry if I left off any pertinent details.
325ci?G35?335i?S4?X5M
02-28-2022, 05:57 AM | #4 |
Rep 1,019
I would also get your independent to check the cylinder lining for scoring. If they see any premature scoring, walk away.
If the block is fine, I would say that depending on the spec and condition, a 50/50 split on repair bill maybe worth it. But if its in a Ok-ish condition, and/or you can find better options. As others said, make them pay in full, or walk. You really don't want to be starting your new journey with a blown motor, and bad juju. BTW, a new S63 long block is around $25K. |
02-28-2022, 08:05 AM | #5 | |
Rep 28
Few questions - does $4k seem about right for rod bearing replacement - what could cause bearings to fail at 35k miles? - is it possible the oil specs are anything other than bearings? The challenge is I don't think I'll find a Silverstone on mugello 2017+ with less than 40k miles and almost fully loaded. I've been casually searching for about a year. That said, if this is indicative of future problems, i need to walk (even with an extended warranty). I'm not so concerned about dropping $1500 to split the repair (2500/1500) with Vroom but I'm really concerned this is a bad sign for more to come. The car is in fantastic condition otherwise but we haven't dropped the pan to check the engine (I'd do this as next step but will incur labor costs so trying to decide if it's worth it). Thoughts?
02-28-2022, 08:44 AM | #6 |
Rep 175
I totally get your dilemma OP... A clean car cosmetically doesn't mean it's a mechanically well maintained car. There's no way to ascertain whether or not if previous owners beat on it excessively. If you went the extra mile to get an extended warranty, addressing the rod bearings and inspecting the cylinder walls for scoring is the least you can do for a peace of mind.
02-28-2022, 12:18 PM | #7 | |
Rep 28
He said because there is no knocking and the flakes are small, he'd be surprised if it's the main bearings, gasket or crank issues. About '90% certain' it's the rod bearings. I'm probably risking $2-3k of service if i take it apart and find bigger issues but if it ends up only being rod bearings and i fix them for 1500 of my money, I'd be okay with that. So long as this isn't a bad sign for the future….
02-28-2022, 09:53 PM | #8 | |
Rep 1,019
Whilst, its not unheard of on these forums to have failure this early. Almost always when this has happened, was on cars that were second hand and there was no info on how the previous owner was treating the car. Personally I would consider walking away, as you don't know the condition of the Diffs, Transfer Case, and Transmission. If the previous owner was getting up on it, without mechanically taking care of the car. All those things could be next. With good servicing, the bearings should last 100k. Even if you get on it every day. Unless you are getting a really good deal on it, price wise. Taking into account all those things could be next. Walk. Last edited by Chilled; 02-28-2022 at 10:20 PM.. |
03-01-2022, 12:49 AM | #9 |
Rep 1,340
You're buying an extended warranty for peace of mind, so I wouldn't walk away. I'd ask vroom to contribute the $2500 towards the extended warranty and fix this at a later time when (if) issues arise. Or pay the $1500 now to fix the rod bearing for peace of mind, and use extended warranty for any other related or unrelated issues that might arise.
03-07-2022, 08:32 PM | #10 | |
Rep 28
I had my guys at Eurosport (great Indy) drop the pan and take the car apart. Thankfully, there were no additional metal materials in the pan, engine and cylinders were spotless, main bearings good- just wear on rod bearing 7. Pump chain tension and other elements checked while all accessible…My guys tell me the car is spotless otherwise and I'm seeing that in pictures as well. Zero scoring Unfortunately, while the extended warranty I purchased does cover the parts and labor on this at 100%, it's 'too early' within the contract to cover. Diagnosed preexisting condition. Candidly, I understand their position and knew that was a likely outcome from the adjuster. As known, Vroom offered to cover about 65% of the repair cost and I knew I was at risk of covering the remaining ($1600), which I now am. That said, I'm getting my dream spec X5M, it's in great condition otherwise after deep inspection, has new rod bearings , a warranty that was easy to work with and will be in effect 60 days from now…36k to 96k/5 years. With proper care from an enthusiast including more frequent and higher quality oil changes, I'm thinking this beast will be solid. I hope I don't eat my words but I'm very pleased with the result here so far and think I still have a winner. Thrilled to be in the f85 community…stayed tuned and thanks again.
02-21-2023, 03:24 PM | #12 | |
Rep 75
02-24-2023, 12:37 AM | #13 |
Cattlecar
42
Rep 141
I think you'll be fine since the cylinder inspection. The rod bearing fault is odd but if that had not been discovered it might have been a long time before it surfaced. That it is handled and crank is fine is a plus. How many of these cars are purchased and "ignorance is bliss" is the way it goes for several thousand miles and no warranty coverage. I am not trying to make you worry about the coverage you got with this car but with many extended warranties engine failures get sticky and they will push used engines and not agree to pay for inspection or peace of mind work before the "new" engine goes in. Enjoy the drive!
02-25-2023, 08:58 AM | #14 |
Rep 28
Thanks guys. This thread is old and I PMd WZS on price of car.
Quick update for those interested- the engine has been great since RB replacement. I absolutely love this beast and I am so glad I hung onto the perfect spec I so desired. The warranty has actually been great as I had another (smaller) issue that they covered with no issue. Car runs great- I think it was a case of not frequent enough oil changes and poor oil choice. Everything running strong now
musa423.00 |
02-25-2023, 12:47 PM | #15 |
Rep 900
02-25-2023, 02:36 PM | #16 |
Rep 237
Drives: F16 X6 M50i
