07-13-2020, 08:28 PM | #23 |
Rep 900
Tire comparison calculator for helping you keep the overall diameter for front and rear similar or within 1%.
https://tiresize.com/calculator/ |
09-23-2020, 09:51 AM | #24 |
Rep 6
Bigger Tires
So, based on Zip22's post - I did it. I ordered a pair of 275x45x21's for the front and a pair of 315x40x21s for the rear on my 2017 X5. I am good with a little inner fender rubbing if that is all the slightly taller tire causes. I will report back when I receive and install these as they will be my "winter set of tires".
09-23-2020, 09:55 AM | #25 |
Rep 6
Zip, are you still running the set up as listed here in the thread? I ordered this week and am pretty excited. How many miles have you put on with this set up so far? Can you please advise where you picked your spacers up (a link if possible) and a snap of the tires now - with the spacers do they sit outside the well at all?
Thanks! |
09-30-2020, 11:52 AM | #28 | |
Rep 6
They then proceeded to try to make me pay for 2 mount and balance jobs, needless to say that didn't happen. I am now awaiting the correct spacers to give this one more go. The tires did look pretty sexy mounted up and held up to the X5 though! |
10-07-2020, 12:34 PM | #29 |
Rep 1,030
10-07-2020, 12:50 PM | #30 |
Rep 287
Drives: 2020 M4
Garage List 2020 BMW / F82 [0.00]
2016 BMW X5 35i [0.00] 2012 Porsche 991 C2S [0.00] 2013 Audi S8 [0.00] 2004 Ferrari Challe ... [0.00] |
JD,
While the width can make a difference, the offset is even more important. Last edited by andrewmr; 10-13-2020 at 11:00 AM.. |
JDE92M3874.00 |
10-08-2020, 12:50 PM | #31 | |
Rep 1,030
JD |
10-13-2020, 10:54 AM | #32 |
Rep 6
Why did you decide to switch back to stock tire sizes being that the ride and handling was improved?
10-13-2020, 02:49 PM | #33 |
Rep 14
After reading through this thread, I ended up going in between for my winter setup. I'm not lowered and have not installed spacers yet. No rubbing. I have 5mm front / 12mm rear spacers I will be installing hopefully tonight.
Stock 285/35/21 - 28.9" diameter 325/30/21 - 28.7" diameter 0.7% difference Winter Setup 275/40/21 - 29.7" diameter 315/35/21 - 29.7" diameter 0% difference |
JDE92M3874.00 |
10-13-2020, 02:52 PM | #34 | |
Rep 6
JDE92M3874.00 |
10-13-2020, 05:04 PM | #35 | |
Rep 1,030
https://f15.bimmerpost.com/forums/sh....php?t=1764709 Last edited by JDE92M3; 10-14-2020 at 07:59 AM.. |
10-13-2020, 05:11 PM | #36 | |
Rep 14
JDE92M3874.00 |
10-13-2020, 05:16 PM | #37 | |
Rep 1,030
scats are you using any spacers at all? No rubbing still? And stock ride height right? JD Last edited by JDE92M3; 10-13-2020 at 08:00 PM.. |
10-13-2020, 08:21 PM | #39 | |
Rep 1,030
JD |
10-14-2020, 07:47 AM | #40 | |
Rep 14
I did install 5mm/12mm spacers last night. I'll post up new pictures after I get a chance to clean her up a bit. |
JDE92M3874.00 |
10-14-2020, 07:51 AM | #41 | |
Rep 1,030
JD |
10-14-2020, 12:09 PM | #42 |
Rep 6
I am honestly surprised you are adding spacers if you don't need them. They look good. Mine stick out a good inch from bottom of the fender with the 30MM spacers. It looks SUPER aggressive but I am going to have to get some rock chip protection film thrown on before I put to many miles on like this.
10-14-2020, 05:24 PM | #43 | |
Specialist
1310
Rep 2,707
JDE92M3874.00 |
10-14-2020, 11:51 PM | #44 | |
Rep 1,030
JD |
NYBulldog1310.00 |
