03-03-2023, 10:44 AM | #1 |
Rep 28
Another tire question.
Ok I’ve read the forum thoroughly and taken notes. I know the sizes I can run on the OEM 20” wheel. I have read how a member ran 275/45-21 315/40-21 with spacers. I know I can run 275/35-21 315/30-21 and this is what I will likely do for an All season tire option for 21s. my question is can I run 295/35 21 square or 295/40 21 square. Stock suspension. I saw one member ran 295/35 but didn’t see if they ran into any issues. Can anyone chime in?
03-03-2023, 11:12 AM | #2 |
Rep 7,486
Run your specs through this calculator comparing your old vs new wheel/tire setup for each axle. Then see if there is enough room for any additional "poke" or "inset": www.willtheyfit.com
03-03-2023, 11:16 AM | #3 | |
Rep 28
03-06-2023, 07:11 AM | #4 |
Rep 59
If you use OEM 21" rear wheel are 11.5x21 and 295 is too tight for this wheel.
Will fit but will be stretch and not ok for tyre. P.S. OEM 20" wheels have a same specs like OEM 21'' P.S.1 OEM winter setup is different specs |
03-06-2023, 11:45 AM | #5 |
Rep 138
Just last week we did the Michelin AS3+ in 275/35-21 315/30-21 and love them!
2018 BMW X5 M in Donington Gray Metallic with Aragon Brown Merino interior, etc.
2016 Audi S8 Plus with Dynamic Package, APR Stage One tune, etc. |
03-06-2023, 12:21 PM | #6 |
Rep 28
On tirerack the 295/35 tires say the rim width range is 10-11.5” are you sure they won’t fit?
03-06-2023, 12:24 PM | #7 |
Rep 28
That seems to be the safest move to run an AS tire on the 21” wheels. I think I will swap to an all season 275/40 315/35 on my 20s for more sidewall and re-asses running a winter tire on the 21” next year and figure out what size for the 21” later
