      12-10-2018, 01:47 PM   #23
2euro
2euro's Avatar
Drives: 2015 X5 50iMSport
Originally Posted by daytonaviolet View Post
hopefully warranty would help with that
Careful with this. If the dealer realizes that you have auto fold when locking, they'll know you've coded the car and will void warranty. At least this is what I have read.
To avoid premature wear on the mirrors, I'd say only fold when you really need to, in tight areas.
2015 BMW X5 50i MSport | Alpine White
      12-10-2018, 02:58 PM   #24
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1250
Drives: 2017 F85 X5M
if i ever have an issue of a fried folding mirror, i'll code it back to non-active and just play dumb with the SA.
i have mine set to long hold, so i have to hold the fob/comfort button longer if i choose to fold usually in tight situations or places where i really want to look cool
2euro98.00
Servord30.00
      12-12-2018, 11:10 PM   #25
DonJuan
DonJuan's Avatar
538
Drives: G82 M4, F15 X5, F30 328d, E30
Originally Posted by sloanbj View Post
Unless I am in a tight parking situation where there would be a benefit to folding them, I don't fold the mirrors. Just shortens the mirror motor life.
Also don't start your car too often, it shortens the life of the engine.
2022///M4 Competition BSM / Fiona Red.
2023 X7 xDrive40i, BSM / Individual Ivory white/Atlas Gray over Piano Black
MSport Pro and Prof.
Appreciate 5
      12-25-2018, 12:44 PM   #26
sloanbj
Drives: 2015 Xdrive50i MSport
Starting a cold engine probably puts more wear on it than anything else you can do to it.
      01-07-2019, 10:58 PM   #27
yober
yober's Avatar
Drives: 2012 BMW X5 xDrive35d
After coding via E-sys it appears that F15 side mirrors are not folding with keyfob.
Strange. There lots of other brands that have mirrors fold and unfold simultaneously during lock and unlock.
      01-07-2019, 11:29 PM   #28
daytonaviolet
OEM CSL Whore
Philippines
1250
Code it with BimmerCode 😇
      01-07-2019, 11:45 PM   #29
yober
yober's Avatar
I understood Esys is better.
After coding the side mirrors fold only after the car is locked and when I hold my finger on the door handle for 3-4 second. And if mirrors are folded, they unfold when the door gets open.
The only hiccup, mirrors don't fold with the keyfob.
      01-08-2019, 03:15 AM   #30
yober
yober's Avatar
After reviewing the cheat sheet carefully, I edited 2 more options related to windows rolling that somehow effecting mirrors. And after this coding now mirrors are folding and unfolding with the keyfob.
BimmerTy192.50
      01-09-2019, 01:34 AM   #31
alphaod
alphaod's Avatar
As far I know if there is a problem they will first reprogram your car. If that fixes the problem then you will likely be charged. If that does not fix the problem, they will fix the problem you have under warranty.
Besides the law is on our side. If the dealer raises an issue, I'd speak to their service manager about the FTC and Warranty Acts. Basically they cannot void your warranty just because you have coded your mirrors. They must be able to prove that your modification is the reason a part has failed. At most they can say your mirror folding functionality failed as a result of the coding. Even then that is a gray area because you are not actually "coding" but more on changing a bunch of settings in the car that is already built-in.
2015 BMW X5 xDrive50i
BMW CCA 509766
DonJuan537.50
      01-09-2019, 08:22 AM   #32
puckybadger
Drives: 2024 X6 M60i LCI TBII/Tartufo
One way to code is with BimmerCode and Vgate obdII.
Inside the BimmerCode app.. you'll see this in the app just set it to Active.
95000 miles later, I did not know the heated seat temp can be adjusted. Mine has always been too hot even on setting 1
      01-10-2019, 03:58 PM   #33
DonJuan
DonJuan's Avatar
538
Me too! I turned level 1 as low as it goes and it's still a little too warm to me.
      01-10-2019, 10:48 PM   #34
anacondatp
Drives: 10' E92 M3 6MT, 15' F15 X5 35i
you can easily code this in. buy an obd wifi plug and use bimmercode app
10' E92 M3 6MT
15? F15 X5 35i
      01-15-2019, 09:38 PM   #35
DonJuan
DonJuan's Avatar
538
I have one, coded it to the lowest temp and still a little too warm at 30c degrees.
      01-15-2019, 09:40 PM   #36
delt31
Drives: TBD BMW
first world problems......my heated seats are too warm. haha love it.
m3fuz199.00
      01-16-2019, 06:26 PM   #37
DonJuan
DonJuan's Avatar
538
I know right? lol good problem to have.
      11-10-2019, 09:01 AM   #38
EdgyE36
Wisdom Searcher
EdgyE36's Avatar
58
Drives: E39 M5 and E46 M3
Good thread. This is what I'd like to do - folding when holding button down, not folding all the time. So it's not a simple on/off in Bimmercode menu, it's something different? TIA.
BLUE HEAVEN
My cars - 2002 Lemans M5, 2006 Interlagos M3
      11-10-2019, 09:56 PM   #39
daytonaviolet
OEM CSL Whore
Philippines
1250
You can choose how long before it folds.
      11-11-2019, 07:25 AM   #40
EdgyE36
Wisdom Searcher
EdgyE36's Avatar
58
Yup, did yesterday and worked great. FYI I found mirrors in the "Body Domain Controller" category on my Bimmercode menu.
BLUE HEAVEN
      11-11-2019, 07:37 AM   #41
DBV1
134
Drives: 2018 BMW X5d 2021 Tesla S
Do your fold immediately when locking the doors? I have to do a long press to make them close after coding this, where as my 2017 5 series fold immediately on pressing the lock button on key fob.
      11-11-2019, 08:21 AM   #42
MK2018
MK2018's Avatar
231
Drives: 2018 X5 xDrive35i
You can code that to immediately as well
Current
2018 F15 M sport x35i
Past
2017 GMC Sierra Denali
2017 GMC Yukon Denali
2016 GMC Yukon SLT
2015 GMC Sierra All Terrain
      11-12-2019, 05:27 AM   #43
DBV1
134
Thanks - I tried coding that too. How did you code that? I am using Bimmercode. Thanks!
      11-12-2019, 01:05 PM   #44
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Why do y'all use the key fob when you just touch the door handle. What's the point of comfort access if you don't use it lol. Mine fold immediately using the key fob but only after holding my finger on the door handle for like 3-5 seconds do they fold.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
