09-12-2017, 11:41 PM | #1 |
Rep 557
Do I need a dedicated winter tire, or just an all season?
I'm sure there's info here and there on the forums, but since I don't have hours to spend reading I'd like to ask directly.
I live in Seattle - we have plenty of rain in the winter and rare snow. Also it's quite hilly. In the past I've used summer tires year round and just avoid driving in snow. On my E70 X5 I ran Continental DWS 06 year round on staggered 20"s and they were great. But, for my F15 X5, I decided to go with 21" 612M wheels with Michelin Pilot Sports which are a no go below 45 degrees. I kept my OEM 19"s as a winter set so I can put whatever tires I want on those for Dec-Feb. I'm wondering what that should be. I was very happy with the Conti DWS, but according to the Tire Rack reviews they're less capable than Pirelli Scorpions which are a couple hundred cheaper too. The Pirelli is a dedicated winter tire and the DWS is an all season. Looking for input for which is the better tire for my needs. Here's a screen shot of Tire Rack comparing Blizzak, Pirelli Scorpion and DWS. |
09-13-2017, 02:24 AM | #2 |
Rep 2,388
In your case I would go with a cheaper and dedicated winter Pirelli. Do not overthink it, you already have summer tires and you already have separate set of rims for winter - so it makes more sense to buy winter set, save some money and have a better grip on those icy hills in Seattle. Blizzak will be overkill for your location probably
Conti DWS is a great all-season tire - I have Conti DWS and I drive all year round (lol I drive from 110F in Arizona to -22F in Ontario on my DWS 06), but I only have 1 set, so in my case I'm stuck with all-season Last edited by DuSh; 09-13-2017 at 02:44 AM.. |
nyalpine907433.00 |
09-13-2017, 08:24 AM | #3 |
Rep 181
I'd just use the OEM 19s for the couple months you may get snow. I've never run summer tires as we get snow 5 months a year so I run all season 12 months a year.
09-13-2017, 10:37 AM | #4 |
Rep 557
DWS is a great tire and I wish they made the sizes needed for 21"s, then I'd just use those year round. But since there's not a single option for a 21" all season in the needed sizes I'm stuck with swapping out for a winter set.
I was leaning toward the Pirelli as well since it's cheaper and seems like it'll perform better in winter weather. |
09-13-2017, 03:43 PM | #5 |
182
Rep 326
Drives: 2021 X5M
go with dedicated winter and summer tires for best performance. All season tires are sometimes called NO SEASON tires. They are not great in the winter and not great in the summer. They just don't suck as bad in the winter as a summer tire and don't suck as bad in the summer as a winter tire.
I have dedicated summer and winters for both our X5's. I have the Scorpion's on mine but Blizzak's also just as good. |
monkiboy534.50 |
09-14-2017, 12:15 PM | #6 |
Rep 557
I think that's good advice - as long as I'm running two sets go with a dedicated winter tire.
So I decided on the Pirelli Scorpion Winters only to find out the load index is 103, and our cars recommended load index is 107. (This is not the Pirelli Scorpion "Snow and Ice" tire which does have a load index of 107, but is a run flat). Are others on here using these Scorpion "winters" without an issue? I definitely don't want to put an insufficient tire on the car, but a load index of 103 equals 7700 pounds capacity. With a curb weight of 4900 that seems fine. Another option is the new Yokohama BluEarth V905 winters which just came out this spring, so there are no reviews on Tire Rack. Just a couple online which are very positive. |
09-14-2017, 12:18 PM | #7 | |
182
Rep 326
Drives: 2021 X5M
09-20-2017, 12:45 PM | #9 |
Rep 557
For those that have experience with a dedicated winter tire like Pirelli Scorpions, would you ever need to use cables in addition? On my E70 I had Continental DWS and cables in the trunk just in case, but the DWS is an all season. Wondering if I can get rid of my cables since I'll be using a true winter tire.
09-20-2017, 12:57 PM | #10 | |
Rep 1,887
09-20-2017, 02:02 PM | #12 | |
Rep 648
Drives: 2016 F15, 2015 F83
Pirelli has a Scorpion Winter with a load index of 107. I bought them last year. Here's the link: https://www.tirerack.com/tires/tires...R9SCORWXLRFTV2
2016 F15 X5 50i M-Sport
2015 F83 M4 |
09-20-2017, 02:12 PM | #13 |
Rep 557
Rotzy - yes I saw those but I was looking to avoid a run-flat. No Tire Rack reviews for these, although I assume it would be similar to the non-run-flat version which have excellent reviews (although the load index isn't right for X5). How was your experience with these?
09-20-2017, 02:23 PM | #14 | |
Rep 648
While I agree that a non-RFT will probably provide better performance, consider this: Do you really want to risk changing a tire on the side of the road after hitting a pot hole in a snow storm? I consider the middle of January through the middle of March a complete waste as far as performance driving is concerned and was happy to put RFT winter tires on the vehicle.
2015 F83 M4 |
09-21-2017, 03:22 PM | #15 |
Rep 535
It depends on what your options are if there is snow outside. I live in Vancouver and often times work in a local hospital and 6am on a Sunday can be expected to show up to work. So I got snow tires for a few days of snow we have. It was a life saver last year sometimes I was the only one showing up to work on time.
I have blizzaks LM 25. I hate RFTs and just keep a spare all season for my bad luck day in the trunk when driving on non RFTs in the winter. |
09-21-2017, 04:11 PM | #16 |
Rep 7,063
Hey I?m local I own businesses up and down I5 and 405 but live south of Puyallup where we get most of the snowfall in the main I areas (45 mins NW of Rainier). Anyways a dedicated snow set from Mid December to February is what I run on whatever my wife drives so if it’s our GL or X5 both have snow tires I think their Bridgestone Blizzard something from Costco. Do fantastic and don’t have to worry about it for her. I personally drive a lift Ram 2500 on mud tires in the winter so I do just fine. But for peace of mind since you already have the wheels do it.
09-21-2017, 04:17 PM | #17 | |
Rep 251
I also invested in a set of tire socks from AutoSock as an alternative to tire chains which are mandatory on certain roads. http://www.autosock.com/en/products.html
2018 M3
2017 X5 35d xdrive Msport Sold: 2014 X5 35i xdrive Msport |
09-23-2017, 08:57 PM | #18 |
Rep 255
Drives: 2021 M-B GLS 580
In Seattle - DWS Conti. Unless you are in Canada no need for a winter required by law.
2020 X5 M50i
2017 X5 50i M-Sport (Retired) 2013 X5 50i M-Sport (Retired) |
09-24-2017, 11:54 AM | #19 | |
Rep 557
10-05-2017, 12:24 PM | #20 |
Rep 251
I got mine through 1010tires.com. Available in load index 109, speed rating V & H
2018 M3
10-06-2017, 03:54 PM | #21 |
Rep 865
I live in Colorado on what is called the Front Range and make at least monthly trips to the mountains all year. I drive all the time in 6 to 8 inches of snow when we have it with the stock run-flats. Previous of the X5, it was stock Bridgestone all-seasons on our Acadia.
To be blunt; all season tires will work fine in nearly all conditions unless you drive stupid in snow. Ice is the real problem and snow tires will make some difference in overall traction, but honestly, just not worth the hassle of switching back and forth. If I actually lived in the mountains, I would switch to dedicated snow tires once temperatures got cold enough. What many fail to recognize is that the rubber compounds used in snow tires are too soft for warmer temperatures. I used to have a set of winter tires that I would switch if I knew I was going to the mountains and was going to be in bad weather most of the time. I found many times that if I was going for 4 days and getting snow for 2 of them, I wouldn't bother. So now I just don't bother anymore at all. I carry chains, but only because Colorado law requires them for passenger vehicles at times and I don't want to wait out the weather for them to lift the restrictrictions. Many times when I am driving in snow, its because I want to get to the mountains to enjoy the snow.
2003 BMW 330i
2016 BMW M4 - ED May 2016, PCD Aug 2016 2017 X5 xDrive35i - PCD Jan2017 |
10-08-2017, 07:48 AM | #22 |
Rep 155
I wanted a non run flat as well that would match stock size for my 20" M-Sport wheel configuration. I decided to try the Toyo Observe GSI-5. So far, I haven't had to drive in the snow with them but as far as dry pavement and road noise they are good. They seem to have good reviews as well. Just throwing out another option for you.
Chad |
