09-28-2018, 12:24 AM | #23 |
Rep 11,722
If coils replaced and still shaking suspect something else like a guibo going bad. Don’t be surprise that bad engine mounts can cause shakiness as well. Good luck buddy.
09-28-2018, 08:10 PM | #24 | |
Rep 1,170
Good call. I think it's the rest of the coils. Might as well swap them all with new ones. Plugs are all new (3-4 months old). I checked dealership servicing papers and saw that coil 3 was replaced but the indy mechanic found coil 3 to be faulty?
2014 X5 xDrive50i Last edited by kanvas; 09-28-2018 at 08:24 PM.. |
09-30-2018, 10:31 AM | #26 | |
[Oo=||=oO]
1103
Rep 2,470
However, if you are having issues with the same cylinder after doing a new coil and plugs, then start looking into other reasons why you might have a misfire. It could be bad injector. If you replace injector and problem is still present, then you would need to do a leak down test to see if your compression is right. If your compression is off, then you might be looking into a bigger issue - bad engine. |
10-08-2018, 02:46 PM | #27 |
Rep 1,170
Just to make sure, there are 8 coils in a V8, right? Just checked a quote from the last mechanic for replacing all 8 coils, but QUANTITY says 6.
2014 X5 xDrive50i |
10-08-2018, 04:41 PM | #29 |
Rep 413
I had the same issue a few times on my 2016 f36 n20. Only happened like 3-4 times within 2 years. Went away every time I restarted the car. Happened once to my new 2018 x6. Both cars had piggibacks installed. Could be related?)
10-09-2018, 12:35 PM | #30 |
Rep 1,170
Thanks everyone for your input! Finally found a trustworthy mechanic and got everything resolved (the previous mechanic was just... confusing). One of the coils was faulty; mechanic replaced and test drove and runs smoothly, but asked to replace the rest since it's just a matter of time before the other ones start going bad!
2014 X5 xDrive50i |
M302_imola842.50 |
10-09-2018, 03:03 PM | #31 | |
[Oo=||=oO]
1103
Rep 2,470
