07-06-2019, 02:03 PM | #4907 | |
Rep 29
Cheers[/QUOTE]
I also have icam2 showing without any cafd file attached. What is your psdz version? |
07-06-2019, 09:44 PM | #4909 | |
Rep 40,789
07-06-2019, 09:45 PM | #4910 |
Rep 40,789
PM sent.
Muzza55.50 |
07-07-2019, 02:15 AM | #4911 |
Rep 111
07-07-2019, 05:20 AM | #4912 |
Rep 26
Drives: mini
I spend a couple of hours on coding today, and did not manage to get it working!. I think we are missing a cafd, I'm not an expert in coding but I have tried almost everything. I also have icam2 showing without any cafd file attached. What is your psdz version?[/QUOTE] My psdz is 4.17.11. |
07-07-2019, 07:29 AM | #4913 |
Rep 26
Drives: mini
Just tried getting CAF for SWE for icam2 again in ESYS and the error it puts up is
"failed to get CAFs for SWE "swf1_00001ee1-016_000_005" [c111]" and then a KIS error. This is way passed my very limited knowledge of coding, I'm going to have a go at flashing the Icam2 ecu (never done before any advice on how to do this would be appreciated), I just need the full PSDZ data. Shawn could you help me with latest full PSDZ as the old link is no longer working, I'm using ESYS 3.27.1 Many Thanks in advance. |
07-07-2019, 10:44 AM | #4914 | |
Rep 40,789
For flashing, if you flash with older PSdZData than ECU, then you will downgrade the ECU firmware.
07-07-2019, 02:12 PM | #4915 |
Rep 26
Drives: mini
My car is a 2016 X5 40d and none of the ecu's have been updated at the dealers as it has been non main dealer serviced, so should be as it rolled off the production line.
07-08-2019, 03:58 AM | #4916 | |
Rep 111
One of your posts even saved my bacon when I messed up the DME's by coding the whole car while running to enable Traffic Jam Assistant as per Quidzel instructions. They really should make it clear not to perform complete coding while car is running! I'm curious now in what it takes to flash the car to the latest and greatest i-step. Would love some advice or even a link if this has already been addressed previously. Are such updates even universal between countries? |
07-08-2019, 07:05 AM | #4917 | |
Rep 40,789
https://mega.nz/#!p9JQhAwZ!JJ9ptw8Ti...JcnSUvG81nYMsw
Muzza55.50 |
07-09-2019, 05:20 AM | #4918 |
Rep 111
shawnsheridan, sorry to trouble you again. I would like to code 8TH, aka the speed limit info. Can you kindly point me to a guide. I understand I may also need to purchase an FSC code, unless that is outdated info and no longer necessary.
07-09-2019, 10:54 AM | #4919 |
Rep 40,789
FSC Code is needed for 8TH. PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 07-09-2019 at 08:36 PM.. |
07-10-2019, 03:44 PM | #4921 |
Rep 40,789
PM sent.
07-11-2019, 01:37 PM | #4922 | |
Rep 29
Just found that I might run out of space on my old laptop!. Do I need all the files to perform ECU flash on my F15??? |
07-11-2019, 02:53 PM | #4923 | |
Rep 40,789
If you are out of space on your local hard drive, you should leave local psdzdata folder empty and put psdzdata folder extracted from PSdZData Full archive on an external drive, and then use Windows MKLINK command to create a Windows Symbolic Link, for example from C:\ESysData\psdzdata to E:\psdzdata.
07-12-2019, 01:51 PM | #4924 | ||
Rep 29
Will give feedback when done :-) |
07-13-2019, 04:57 PM | #4925 |
Rep 106
I hate it when the car automatically adjusts/steps down the heated/cooled seats from the high to medium setting after 5 or so minutes. Is there a way to code that off?
07-13-2019, 10:58 PM | #4927 |
Rep 40,789
PM sent.
07-14-2019, 10:01 AM | #4928 | |
Rep 923
https://f80.bimmerpost.com/forums/sh...3&postcount=30 I coded it into mine and it works fine based off the info above. |
Muzza55.50 |
