11-01-2017, 08:48 AM | #3 |
Rep 18,777
Can-am , looks nice.
May I know what brand of spacer on the front? Have you take off the wheel again and check that the spacer are still in 1 piece?
11-01-2017, 10:58 AM | #5 |
Rep 18,777
The front hub height will not clear 15mm.
I wonder how it can clear 12mm. Unless if it is not hubcentric. If it is not hubcentric, your front wheel is not properly seated on the hub and you are putting a lot of stress to the lug bolts, which is not safe.
11-01-2017, 11:16 AM | #6 |
Rep 18,777
Hmm, looks like they have different design than H&R. I may have to order 1 and take a look.
But this is what happened with 15mm. http://f15.bimmerpost.com/forums/sho...2&postcount=98
11-01-2017, 11:21 AM | #7 | |
Rep 18,777
But, do double check, make sure it didn't break.
11-01-2017, 11:21 AM | #8 | |
Rep 2,194
I went with the 5mm based off of Ben's research on the matter. |
11-01-2017, 11:50 AM | #9 | |
Rep 18,777
The rear have no problem with 20mm.
11-01-2017, 12:55 PM | #10 | |
Rep 18,777
All good. I will inspect it before you go any further. When it break, it won't be fun. Better be safe than sorry.
11-01-2017, 01:17 PM | #11 |
Rep 4,532
Kudos to RGSPORT for stepping up with the tech data.
r33_RGSport13099.50 |
11-01-2017, 03:52 PM | #12 |
Rep 144
Just curious might be a really stupid question but what would happen if you installed 2 5mm spacers? Obviously having 1 piece would be ideal but i really dont understand how that happens to the front. What exactly is wrong with their design that this happens? is it the spacer not having a large enough lip?
2008 Alpine White M6-6MT (Fully Modded S85 w/ Dinan, RDSport, KW, Akrapovic, and Brembo) |
11-01-2017, 05:44 PM | #13 | ||
Rep 18,777
If they are not broken, then you are fine. If you take them off, it is ok to just run the rear. Quote:
Therefore, you will only have about 2mm left on the hub lip to support the weight of the car to the wheel. You can read through my spacer thread from the link that I posted. In a nutshell, BMW changed the front hub assembly starting MY11/14 to have a longer hub lip into a little over 15mm. And usually 10mm to 15mm spacer are hub centric, which means, it have the extended hub lip the same diameter as the original hub lip. With 10mm to 15mm hub centric spacer, they also have 10mm to 15mm depth to clear the hub lip. With a little over 15mm hub lip and in this case only 12mm depth, the spacer won't sit flush against the rotor. So, by the time you put on the wheel and torque it, you are forcing the spacer to sit flush against the brake rotor and snap that hub centric ring. Even less than 1mm gap, will cause it to break. It was a $500 lesson for me. So, please donate?? Hahaha.
11-02-2017, 01:26 PM | #14 | |
Rep 18,777
If I call or talk to anyone at Eibach, they will get back to you with"It does fit as stated in the Catalog". Same thing with H&R. There are a bunch of small disclaimers they you need to read, such as the hub height clearance is customer's responsibility to check before install.
11-04-2017, 03:48 PM | #15 | |
Rep 18,777
I guess I'll order one to check the difference.
11-04-2017, 11:46 PM | #16 |
Rep 944
Ben,
How many miles on your before you saw the damage. Really interested to see if eibach has a different design that might work. 12m in the front is exactly what I need |
11-05-2017, 08:22 AM | #17 | |||
Rep 18,777
The rear fitment is fine. Quote:
Yea, I'll order a set of Eibach tomorrow and confirm the fitment.
11-05-2017, 03:21 PM | #19 | |
Rep 144
Also a big thanks to RGSport for ordering a set to test! Im sure many of us will appreciate your feedback to know that we can use larger then 5mm upfront if all works well.
11-06-2017, 03:48 AM | #20 |
Rep 15,818
If this for sure works after r33_RGSport double checks to confirm, Can-am please forward me your paypal, I would love to pay for your next beer as a sign of appreciation.
IG:d.violet.m3
JcLusso581.00 |
11-06-2017, 11:28 AM | #21 | |
Rep 18,777
In the meantime, I will still recommend 5mm front and 15mm H&R setup.
11-08-2017, 11:43 AM | #22 |
i build cool shit
581
Rep 712
Drives: 2018 Individual SMB F80 M3
Super interested to see where this goes! Patiently waiting for r33_RGSport to confirm fitment
