03-19-2020, 08:50 PM | #133 | |
Rep 275
03-19-2020, 09:02 PM | #134 | ||
Rep 1,859
Drives: 23' X7 40i M Sport
04-01-2020, 02:25 PM | #135 | |
Rep 1,975
If OP reports back that the rear does not bottom out with weight in the back and he is happy with the ride quality then BC might be the way to go. Or if Silvers has developed a stiffer barrel spring for the rear of their kit then that might be the way to go.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
04-06-2020, 05:11 PM | #136 | ||
Rep 1,859
04-07-2020, 02:04 PM | #137 | |
Rep 1,975
04-07-2020, 02:34 PM | #138 | ||
Rep 1,859
In other news I did have an unusual experience with the rear maybe you could weigh in on. Yesterday while going over a small speed bump I heard a very loud "TWANG!!!". Only lasted a second and my driving experience after was fine. Thoughts?
04-07-2020, 02:57 PM | #139 | |
Rep 1,975
04-07-2020, 02:58 PM | #140 | ||
Rep 1,859
04-07-2020, 03:09 PM | #141 |
Rep 1,975
Not sure. I'd see if you can reproduce it. If you can, the only thing I can think of is to make sure everything is torqued down properly.
04-23-2020, 11:23 AM | #142 |
Rep 1,975
How's everything going? Curious if you've done anymore testing?
04-23-2020, 09:53 PM | #143 |
Rep 1,859
Hey man, so far so good!
06-01-2020, 09:03 AM | #144 |
Rep 592
06-01-2020, 07:37 PM | #145 |
Rep 428
Drives: 2015 X5 35d
I ordered a set of silvers last week. They will take 2 weeks to be made and sent to me. I'm very exited to get them on.
06-02-2020, 05:12 PM | #146 |
Rep 1,859
Hey, so I'm still very happy with the BC Racing Coilovers. I am in New England where the roads suck, and thought my experience on 22s was going to be a kick in the nuts lowered. It's surprisingly comfortable over the bumps and potholes. That said I am on max soft dampening at the moment but it was a little harsh on the out of the box settings. The stance is great at 30" all around even with a little excessive negative camber. I am installing camber kits next week because I am anal about a super flush look but they are not necessary.
06-02-2020, 05:32 PM | #147 | |
Rep 592
06-02-2020, 08:47 PM | #148 |
Rep 1,859
Blank
It's an vastly different experience and my statement may sound contradicting but here it goes:
You can feel little ripples in the road more than the stock ride going down a reasonably smooth road, but overall it's more comfortable / less impactful to your core when going over potholes. The handling feels tighter on the highway on-ramps at high speeds, but all and all it's tough to beat the comfort and broad stability of the stock suspension sitting up high. There are concessions made but the overall gains are easily made up. Also I forgot to mention that the initial break-in period is a little nerve racking but once you've tweaked the springs, adjusted your ride height, dialed in your dampening and waited patiently to perform a final (second) alignment, you will be rewarded! My experience post install was a little rough but I stuck in there and got to where I needed to be. I feel like BC Racing make a quality product and are still building their brand. They will never match KW and the pricing reflects that. For someone like me who isn't tracking but wants to the benefits of a coilover at a reasonable price, it's a good balance.
X5Brian871.50 |
06-03-2020, 04:38 AM | #149 | |
Rep 592
Ok .. Thanks. |
08-25-2020, 08:14 AM | #150 | |
Rep 20
I think BC choose spring rates that are simply too soft all around. The truck rides well and is comfortable and I'm happy with the purchase but I will be reaching out to BC to see if they have any suggestions/options on spring rate changes front and back that will help avoid this issue and stiffen it up slightly. |
12-30-2022, 09:12 PM | #151 | |
Rep 44
12-31-2022, 10:12 PM | #152 |
872
Rep 343
I run BC on mine. I have swift springs, 16k front, 20k rear. Have mine stiffer to keep rear from bottoming out. Tried 24k in rear but a little too stiff. Prob gonna order 22k soon now that I have my 22” wheels on… I can’t tuck due to widebody and rears are 13” wide but I need to lower rear about 1/4 to 1/2 inch more to match front with still ha wing a slight rack - and don’t want to bottom out.
I have from adjustable camber arms, rear camber arms, adjustable toe arms … to keep aligned and camber in check. 2023… going to bags on all 4 corners |
01-01-2023, 09:06 PM | #153 | |
Rep 30
