03-31-2020, 09:24 PM | #1 |
Rep 58
2014 X5 f15 climate control button replacement?
Anyone know where I can get a set of replacement climate control buttons for an f15 X5? I see replacement sets for previous X5 models on EBay but haven't found anything for the f15.
As you can see in the pic, the fan speed button is worn and I'd like to replace just the button without having to replace the entire unit. Thanks. |
03-31-2020, 10:41 PM | #2 | |
Rep 885
http://bmwfans.info/parts-catalog/F1...control_panel/ https://www.ebay.com/sch/i.html?_fro...panel&_sacat=0 |
Machetero36.00 |
04-02-2020, 07:26 PM | #4 |
Rep 159
There is no part number for "just the button" So unless you luck up and find one on ebay or go to a boneyard that has an F15 has one (difficult), and pry it off, you are going to have to buy the whole unit.
04-03-2020, 01:19 PM | #6 |
Rep 2,511
These are sold as one piece, and you can find a cheap used panel on Ebay, not worth replacing just one button. It is also a good opportunity to switch to ceramic controls.
04-03-2020, 02:02 PM | #7 | |
Rep 885
Got my eye out for cheap listings, so far nothing under $200 OP: https://www.ebay.com/itm/FRONT-AUTOM....c100008.m2219 https://www.ebay.com/itm/OEM-2014-20...cAAOSwraNdJT8M |
04-03-2020, 03:27 PM | #8 | |
Rep 7,449
If you use one of the online database sites...enter the last 7 digits of your VIN, then go to he climate control diagrams...you’ll see the repair kit diagram and part Nbr’s for the set that you need (there’s 3 different sets): https://bimmercat.com/bmw/en/search/...73/61316848887 ECS Tuning (found doing a google search using the 11 digit BMW part number for the “no climate control front seats” kit: https://www.ecstuning.com/b-genuine-...o/61316848886/ ECS Tuning (found doing a google search using the 11 digit BMW part number for the “with climate control front seats” kit: https://www.ecstuning.com/b-genuine-...to/61316848887 For the climate & radio kit...there are multiple selections based on how the vehicle is optioned (ceramic dials/heated seats yes or no or combination of either): https://bimmercat.com/bmw/en/search/...iX/USA/64_2021
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-10-2020 at 09:16 PM.. |
04-03-2020, 03:41 PM | #9 |
Rep 58
Thank you very much. I just called the parts department and they do have a replacement button set for the F15 - It is $120.
Not sure it's worth it to replace one button but at least I know where I can get them. |
04-03-2020, 03:47 PM | #10 |
Rep 7,449
Go back to post #8...I wasn’t done with my reply. It appears there are sets sold by online vendors for less...ECS Tuning sells the climate control set for approx $60 depending on which set you need (that still may be costly for just one button). The button sizes are different depending on if you have climatized front seats or not...so if you buy....make sure you order the correct kit based on how your X is optioned.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-04-2020 at 06:10 PM.. |
04-04-2020, 12:17 PM | #11 | |
Rep 2,511
https://www.ebay.com/itm/BMW-X5-X6-F...D/383453471800 $100 https://www.ebay.com/itm/2014-2018-B...M/133346386182 And I've seen couple of ceramic conversion kits for $500-650 for panel,shifter and iDrive controller. |
04-10-2020, 05:00 PM | #13 |
Rep 885
Hey Machetero , do you still need the button replacement?
If anyone needs any of these parts, I guess OP would have dibs on the AC button array if still in need. The reason I'm not listing the entire module in classified section is that I took the ceramic controls from this unit for myself, and I'm keeping my non ceramic knobs as backup. So I figured I can part out everything here except knobs for anyone interested. Both button arrays are in great shape, the front face is in good shape too, came off a totaled donor, 06/2014 board. Last edited by maDjzo; 04-10-2020 at 06:06 PM.. |
04-21-2020, 12:56 PM | #15 |
Rep 58
Thanks MaDjzo for the deal on the climate control buttons.
Swapped the old one out today. Here is a before and after: |
4
09-21-2020, 01:08 PM | #16 | |
Rep 2
The video linked above the person swapped the boards which wouldn't be an option for me since it isn't working correctly. |
09-21-2020, 01:51 PM | #17 | |
Rep 7,449
09-21-2020, 02:20 PM | #18 | |
Rep 2
Thanks for the information! It does have a link for "Carry out vehicle programming/encoding" so I'm pretty sure it will have to be programmed unless this is just to change options? https://www.newtis.info/tisv2/a/en/f...ols/1VnXiieTpI |
