04-01-2020, 09:57 PM | #1 |
Rep 685
Drives: 06 Black Sapphire Z4MR
Brake Pad Sensor refuse to turn off
Replaced the pad sensor (oddly, the wires was torn, most likely from when I brought the car, the monkeys at the dealer did not know that it was important.)
Anyways, got the sensor back in, plugged in no problem, but the brake pad low warning light still comes back on I tried to reset the brake pad warning light as well, but says reset unsuccessful. Does anyone have any idea what else it can possibly be?
Revolution of our Times
I will return to the track, one day. |
04-02-2020, 07:43 AM | #3 |
Rep 685
I already replaced it, everything is in the right place, but it still comes back and says reset unsuccessful.
04-02-2020, 10:37 AM | #5 |
Rep 7,475
You have two brake pad sensors (front left wheel & rear right wheel). Can’t tell from your post if you only replaced the brake pads and sensor on one axle or both axles. If you only replaced one axle and you also installed a new brake pad sensor and the wires to the sensor are also intact...but the light still comes on...did you check the condition of the brake pads and sensor on the other axle? If not, could the check control warning be due to the pads & sensor on the other axle?
04-02-2020, 12:39 PM | #6 | |
Rep 685
Though what is odd is that when you press and hold the reset switch on the dash to reset your warnings, the fronts shows in red, but the rear is also says low, most likely the mileage warning, and I cannot reset that either.
04-02-2020, 09:40 PM | #9 |
1636
Rep 2,995
The brake sensor is just a wire embedded in the plastic. When it wears down, the circuit opens, and triggers the brake replacement message. And you won't be able to reset the brake light, if the sensor is not closing the circuit. Since you said you had ripped wires, double check for any cut wires. You could ohm meter the sensor to make sure it's closed. Or put a jumper wire in the connector to see if that allows you to reset.
04-03-2020, 01:55 PM | #12 |
Rep 159
Instead of everyone randomly guessing... you can simply run ISTA and it will tell you EXACTLY what sensor is at fault and how to fix it. A copy of ISTA and a $18 ENET cable will do all of this work for you.
04-03-2020, 02:50 PM | #14 |
188
Rep 364
Drives: M2C X5M M4
If the front won't reset after a sensor change it could be an implausible signal fault stored.
If the cbs see's the pad go from a newish pad to half won (sensor wire damaged so thinks it's worn through) it can store a plausibility issue as it's not technically plausible. So may need clearing this fault. Other thing is sometimes they get confused if your rear sensor is newish trying to reset the rears may allow you to reset the fronts. Seems to nudge the cbs along somehow Another thought sometimes it doesn't like the parking brake on or auto hold active when trying to reset And lastly after the car has gone to sleep it will wake up with the pads reset even after saying it's unsuccessful. And also after waking up try the reset again I've had nightmares with cbs before and the above are something's I've tried and have worked. |
04-03-2020, 03:15 PM | #15 |
Rep 159
Are you kidding me? It will tell you exactly which sensor is faulting, what to do step by step, and whether or not the wire needs to be replaced or an adaptation needs to be run. But feel free to waste time going back and forth on a web forum for days when a simple call to ISTA could tell you in 5 minutes what is wrong.
04-03-2020, 03:38 PM | #16 | |
199
Rep 351
Arteezy13.00 |
04-03-2020, 06:17 PM | #18 | |
Rep 159
Also, after asking that question none of the answers were completely correct. The second battery is specifically for the EPS system. |
04-03-2020, 06:29 PM | #19 | |
199
Rep 351
04-03-2020, 06:45 PM | #20 |
1636
Rep 2,995
04-03-2020, 06:46 PM | #21 | |
1636
Rep 2,995
04-03-2020, 06:49 PM | #22 |
199
Rep 351
Then I will be the first to say I was wrong. I just had 2 cars in for brake service and they did not calibrate anything other than use ista to disengage the electric brake so figured it wasn't needed
