      04-05-2020, 03:10 PM   #1
TheUltimateDrivingManiac
Freude am Fahren.
Drives: F15 X5 xDrive35i
Bored? Here's a Wireless Charger DYI for You
Hey guys,
I was looking for a way to charge my phone wirelessly in a car for some time now, but all available solutions just do not work for me:
1. OEM: charging pocket and charging snap-in do not work for me simply because they are located in the armrest box - I will forget my phone in the car 100 times out of 100;
2. BMW charging station: it's just a bad design that takes away a 12v socket and a cupholder;
3. Charging pad available from Aliexpress, for example here: https://www.aliexpress.com/item/32992569538.htm - same as BMW charging sation - takes away cupholder and 12v outlet (though it gives you back an extra USB-port)
So if you cannot buy it - build it yourself - especially since we all have some time to spare. I've decided to use a small pocket next to a 12v socket - it fits my iPhone X perfectly. As my car came with the smoker's package (but I do not smoke), I decided to utilize an ashtray as a housing. After some experimenting and a bunch of different parts from Aliexpress, I ended up using these components:
1. Fast charging wireless pad: https://www.aliexpress.com/item/4000263350537.html
After experimenting with some Qi PCBs I've ordered, I ended up using the parts sourced from this pad, as it got all the components in a tiny module that was easy to hide inside the ashtray. As well it supports fast charging. On the minus side - initially, I was planning to go with a tri-coil design, but it was harder to fit in an ashtray.
2. 12v to 9v module - you have to supply 9v to make fast charging work. https://www.aliexpress.com/item/32861098806.html
It got operating temperature from -40 to +85 and is waterproof.
I've used plastic mash from a dollar store to mount the charging coil and decided to cover everything with a anti slip mat - it looks decent, easy to cut and will hold the phone in place.
Anti-slip mat: https://www.amazon.ca/gp/product/B01EIY01IE/
While putting electronic components together was quite simple, putting everything together required some experimenting:
After my charger was ready, I've removed the cupholder assembly and connected it to the 12v socket wires.
You can follow TIS (https://www.newtis.info/tisv2/a/en/f...les/1VnXgP85Hp) or r33_RGSport's manual for kneepads retrofit.
And here's the finished product:
Freude am Fahren.
Appreciate 5
maDjzo861.50
MizikeTSK143.50
F15GorDe261.00
      04-05-2020, 04:47 PM   #2
Kraftwerk AG
Kraftwerk AG's Avatar
460
Drives: Mein F Fünfundachtzig Einhorn
Genius! I like it your prototype. So many questions, is it plug n play? Is it removable? How much? When do you start production? I want one. Sadly, my iPhone 11 Pro is the largest phone that will fit in the oem wireless cradle atm.
“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
      04-05-2020, 05:34 PM   #3
Freude am Fahren.
I was working on it since 2018, so I don't think I want to do it ever again Let's hope our Chinese friends will copy it and sell it on Ali
It's not plug-n-play - I had to solder it to the 12v outlet wires, but it can be done that way, I just didn't have a connector I could use at home and I didn't want to postpone this project any longer.
Maybe, someday, I will attempt a tri-coil setup and a connector, but I doubt it.
Freude am Fahren.
      04-05-2020, 11:18 PM   #4
skoold2003
skoold2003's Avatar
2014 X5 50i  [7.50]
I did a similar project last year. I don't have the patience to do a DIY buy I posted some info on it here.
https://www.bimmerpost.com/forums/sh...php?p=25172367
      04-05-2020, 11:23 PM   #5
Freude am Fahren.
Yeah, I remember it. You lost a power outlet and a cover though.
Freude am Fahren.
      04-05-2020, 11:26 PM   #6
skoold2003
skoold2003's Avatar
2014 X5 50i  [7.50]
That's true, and my phone heats up and doesn't seem to charge very fast using it. I usually end up plugging it in anyway
      04-06-2020, 10:39 AM   #7
Freude am Fahren.
From the view of your pad, more specifically, the hollow in the middle that I see, a phone is too far above the coil. Get rid of the hollow, make the pad flatter, and it should work better.
Freude am Fahren.
Search this Thread:
Advanced Search
