02-14-2019, 12:02 PM | #1 |
Rep 239
how to remove the M1 M2 button
Anyone know how to remove the M1 and M2 button? I have a set of blue one wants to install. it looks like 2 taps hold it. can I just pull it out? Just checking before I do it LOL
08-18-2019, 05:03 PM | #3 |
Rep 142
Drives: 2016 BMW X5M & 2018 JLUR
i'd be interest to know as well. I recall seeing a tutorial from IND for removing the start button that required you to remove the entire panel (pain in the arse). And then came a video that you could just pop out the button with some sticky stuff...
Current: 2016 X5 ///M Donington/Mugello Red
Previous: 2010 X5 ///M, 2006 X5 4.4i & 2003 X5 3.0i "BMW El Placer de Conducir" |
08-19-2019, 03:53 PM | #4 |
Rep 106
Drives: BMW x5m 2015
08-19-2019, 04:12 PM | #5 | |
Rep 142
08-19-2019, 05:55 PM | #6 |
Rep 106
It takes arround 10mins all arround to change I did it without removing the steering completely.. just pull the airbag, disconnect, remove the Y trim, unscrew the left paddle shift and unscrew the buttons thats it
09-24-2019, 09:17 PM | #7 | |
Rep 142
Use the trim tool where the black arrow is pointing and pry out the button, then press in the red ones and presto! Patience is the key word here. Not much force to pop out.and it popes out easily. Attachment 2148630
Previous: 2010 X5 ///M, 2006 X5 4.4i & 2003 X5 3.0i "BMW El Placer de Conducir" Last edited by Chile1; 06-21-2021 at 06:58 AM.. |
Blewx5m128.00 |
09-26-2019, 02:57 AM | #8 | ||
F86, G05, E91
455
Rep 778
Bobby_Drake388.50 |
09-26-2019, 03:00 AM | #9 | ||
F86, G05, E91
455
Rep 778
09-26-2019, 03:03 AM | #10 | ||
F86, G05, E91
455
Rep 778
04-26-2021, 02:26 PM | #12 |
Rep 271
You have to remove air bag and steering wheel to remove M1 M2 buttons. No other way. It is very simple to do it. there are several videos on youtube. I did it and whole process took less than 30 mins. You have to remove negative terminal and let the car still for 15 minutes to drain the power completely before removing the air bag. F85/ F86 has two batteries so I removed negative terminal on both.
04-26-2021, 05:55 PM | #13 |
Rep 90
You don't have to remove the steering wheel. You can look through this thread:
https://www.bimmerpost.com/forums/sh...php?p=27173996
2016 X5M DGM BM3 Stage 1 91
RK Autowerks Intake & RW Carbon parts |
04-26-2021, 07:46 PM | #14 |
Rep 988
I just did this, when I bought a new Alcantara steering wheel. You need a very tiny screwdriver to pry the side up. When I bought a blue M1/M2 buttons, it came with a tiny screwdriver, the kind someone would use to glasses, and this black tar stuff that was super sticky, that you apply to the button in order to pull it loose. I even have a thread on this.
