02-07-2019, 09:34 PM | #23 | ||||
Rep 1,343
02-07-2019, 10:31 PM | #24 | |||||
Rep 155
I want to buy dual tips and will probably take off the exhaust flap all together when installing it.
2020 X3M
2018 X5-Msport |
Russmov1328.00 |
02-07-2019, 10:45 PM | #25 | ||||||
Rep 1,343
02-07-2019, 10:47 PM | #26 | |||||||
Rep 155
Vibrant 10632 StreetPower Oval Muffler https://www.amazon.com/dp/B0031TQE84..._OMqxCbKD8YDJA
2020 X3M
2018 X5-Msport |
Russmov1328.00 |
02-08-2019, 03:19 PM | #27 | ||||||||
Rep 282
10' E92 M3 6MT
15? F15 X5 35i |
ggunn9160.00 |
02-13-2019, 03:00 PM | #29 |
Rep 155
I also permanently unplugged the exhaust valve and sounds much better now
with bimmer link it only works after you connect wifi to obd and keep it on, so i open it up using the app and then unplugged the cable underneath. def sounds better this way
2020 X3M
2018 X5-Msport |
02-14-2019, 10:44 PM | #32 |
Rep 1,497
I'd like to unplug the exhaust valve as well. Any drawbacks to this?
02-15-2019, 03:19 PM | #33 | |
Rep 155
2020 X3M
2018 X5-Msport |
M302_imola842.50 AECDY299.00 |
02-15-2019, 04:10 PM | #34 |
Rep 227
02-15-2019, 04:41 PM | #35 | |
Rep 155
was thinking of getting the JB4. not sure if that will increase the sound tho
2020 X3M
2018 X5-Msport |
02-17-2019, 05:39 PM | #37 | |
Rep 155
2020 X3M
2018 X5-Msport |
02-18-2019, 04:34 PM | #38 |
Rep 1,354
Drives: 2022 X5 m50i
I'll be using 2 Vibrant resoinators in the back to replace the OEM muffler on the 50i. I am hoping that the sound will be good. I just could not decide yet if I should go with quad 3.5 inch staggered tips or quad 4inch staggered tips. Any sugestions?
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
02-20-2019, 05:45 PM | #39 |
Rep 155
3.5 should be fine. Depends how much stick out too. Share the link on which ones you're looking at?
2020 X3M
2018 X5-Msport |
02-20-2019, 06:34 PM | #40 | |
Rep 1,354
https://ebay.us/MYSlEn https://ebay.us/8H6Kts https://www.amazon.com/dp/B07N6JRGNQ..._jfFBCbN2W7QS0 3.5-inch ones: https://ebay.us/jqV349 https://www.amazon.com/dp/B002OQNDYI..._sfFBCbCGZAFTM https://www.amazon.com/dp/B07G741T9C..._.hFBCbFJXE87Z
2022 BMW X5 m50i
06-01-2019, 07:05 PM | #41 |
299
Rep 352
Do you get any errors when disconnecting the valve?
03-12-2021, 11:55 AM | #43 | |
Rep 178
In other words has anyone taken the fiberglass sound deadening out, left internal muffler piping the way it is and resealed the muffler. I currently have the muffler cut open and removed the fiberglass deadening, I wanted to know what would happen if I just reweld the muffler shut after sound deadening removal. Also, what is the skinny little pipe for? Thanks in advance Using the pics from the post |
05-18-2021, 09:33 AM | #44 |
Rep 1,497
Dropped my car off last night for get the Vibrant (10632) muffler installed this morn and he called and gave me some bs story that I would have to take it somewhere else. Says the vibrant muffler is smaller than OEM so the pipes that exit the muffler will have to be fabricated (said the OEM pipes were to short) and that would require MIG welding in which he doesn't do. Personally, I don't think he wanted to mess with it. I asked him if Maxi Muffler could do it and he acted like they couldn't do that type of welding either. He commented on the electric valve on the passenger side that opens and closes. He said I'm not sure what we can do with that since new piping will be installed there. Anyhow, what a nightmare. Some many guys here on the forum run this muffler without any install issues. Maybe I took it to the wrong place. Those that have had it installed who did your install? Were any issues that I mentioned above brought up?
