02-21-2019, 01:57 PM | #2 |
OEM CSL Whore
1250
Rep 1,476
i have a set of h&r 15mm w/lugs #3075740 available. these came off the rear of my car. not sure if they will fit fronts.
02-21-2019, 02:53 PM | #3 |
Rep 1,497
Center bore is the same both front and back so not sure why they won't work on the front. The sticker on the box in your pic mentions 30mm so you sure these are 15mm? Are the lugs black? I'll shoot you a pm.
02-21-2019, 06:24 PM | #4 | |
OEM CSL Whore
1250
Rep 1,476
the box adds the width of both spacers, thus 30mm. according to Ben from RG, these rear spacers would not fit on the fronts? or perhaps i got it backwards, perhaps the front spacers wont fit on the rears? paging Ben |
02-22-2019, 12:49 AM | #6 |
Rep 442
I woulda gave you my h&r set for cheap but the hub ring on them broke off not sure how or why :
M302_imola842.50 |
02-22-2019, 09:37 AM | #7 | |
Rep 1,497
Let me measure and see if 12mm will be aggressive enough up front. Curious as to why you have a brand new set? |
02-23-2019, 05:15 PM | #8 |
Rep 1,497
Ok so the wheel spacers daytonaviolet has won't work for my application. The correct part # is 3075742 for the 15mm. Ben, also states that the 12mm won't work on the front. Back to the drawing board. Anyone got the correct 15mm and 20mm spacers they're looking to get rid of?
03-05-2019, 10:13 PM | #10 |
Rep 116
I've got a set of 15mm with the black extended bolts. Part # matches.
Ran them up front on my '15 50i for about a month (30mm on the rear). I left them off last time I rotated my tires. PM me if you're still in the market.
2011 328i (turned-in); 2012 Z4-28i (traded); 2013 X5-35d (traded); 2014 228i (traded); 2015 X5-50i (traded); 2017 X1-28i (traded); 2018 X1-28i (traded); 2018 330i(current); 2019 X6-35i (current)
03-06-2019, 10:43 AM | #11 |
Rep 116
Bought them from Ben last October for $160. I'll mail them to you for $110.
03-08-2019, 08:09 AM | #12 |
Rep 1,497
03-08-2019, 10:01 AM | #13 |
Rep 116
It's on the way. USPS said it should arrive Monday.
PM'd you the tracking #. Feel free to give me a hollar if you run into any issues.
M302_imola842.50 |
