05-10-2021, 01:36 PM | #1 |
Rep 6
Intro-New (used) X5
Hey all,
Long time lurker, new to the X5 but not BMWs. In the past I've owned: -E36 328IS with S52 swap -E36 M3 -E46 330i ZHP Recently picked up a 2015 BMW X5 Xdrive35i w/ 65k from a local dealership. It was an imported Canadian X5 but as far as I can tell there is minimal differences between the US/CAN version, unless I'm mistaken? My X5 was optioned with the M Sport package including M leather steering wheel and aero package, with staggered 20" M Sport wheels. I've done a bit of reading on here, and am basically looking for DIY maintenance tips/suggestions. I've always done my own work on my vehicles unless it's warranty related. This is the wife's daily, so 90% is short 5-10 mile trips. On occasion we do take it on long road trips so I want to ensure it's up to the task for 1,000+ mile trips. The X5 currently has ~70k on it, and I'm looking to replace the spark plugs. From what I read, the Bosch ZR5TPP33 are the OE recommended plugs, correct? I price checked my local dealer (who were way higher than ECS & FCPEuro) and they recommended replacing the coils as well? Is this normal? On cold starts, I do notice a low idle which goes away when I give it a quick rev. Other than that no other noticeable misfires. Second Issue: I'm assuming our X5 is on the original pads/rotors. On a spirited drive with heavy braking, I do get some vibration as the rotors heat up, and the brake pedal travel is longer than I'd prefer. As such, I'm planning to replace all four corners pads/discs. Does everyone recommend staying OEM/OE? ECS has a good deal on Powerstop Rotors/pads. They claim OE style, and I've never had issues with ECS orders in the past. Or should I stick with BMW OEM/Zimmerman rotors? My braking goals are: Stock-ish performance, with rust prevention and rotors that won't warp easily when hot. To sum up: I've been out of the BMW game for a few years. Is FCP Euro and ECS still the go to online parts stores for our BMWs? |
05-10-2021, 03:34 PM | #2 |
147
Rep 334
FCP and RockAuto for me. Some people hate ECS with slow shipping.
With low distance driving and the presumed MFG date of 2014 for your x 2 batteries, a trickle charger would be a good idea. The smart battery charging in the F15 is not always giving voltage to charge up the batteries. I'd go Zimmerman/Akebono, save some $ and lower dust than OEM. CAN to USA... you probably have Xenon Fog/Driving lights instead of the LED option. Welcome to the club. I'd do plugs / coils. Two sets of plugs for one set of coils. T-Case + Front and Rear Diff. Transmission pan / fluid change. |
05-10-2021, 03:51 PM | #3 | |
Rep 182
05-10-2021, 07:37 PM | #4 |
147
Rep 334
05-13-2021, 10:54 AM | #5 |
Rep 10,249
If you are planning to replace the brakes, I suggest to also replace brake fluid and brakes lines with aftermarket stainless steel reinforced lines.
Nice car! |
05-13-2021, 01:24 PM | #6 |
Wisdom Searcher
58
Rep 193
Congrats. Recently bought rear rotors and pads kit from FCP, barely $200. I think the stock Canadian fogs are halogen, not Xenon. There are aftermarket LED conversion kits.
Might want to change the transfer case fluid. We were having issues, feels like power loss while turning. My indie flushed it twice and symptoms gone. Said the transfer case isn't robust and something about the larger M tires in front add to the strain. There are some threads about this. Plugs and transmission fluid on my list for this year or next spring. Miles aren't going up fast work from home.
BLUE HEAVEN
My cars - 2002 Lemans M5, 2006 Interlagos M3 |
05-13-2021, 06:53 PM | #7 |
Rep 2,736
Looks like the car washes are using more acidic cleaners wherever it was washed.
The shadow line trim will need to be polished. Not to much as you will wear through the black coating. Then after their all shined up throw a little ceramic coating on it to protect it from further tarnish or oxidation. |
05-14-2021, 11:41 AM | #8 | ||||
Rep 6
Thanks for all the replies!
Thanks for the service info, making an order from FCPEuro shortly. Quote:
