05-18-2020, 12:28 PM | #1 |
528
Rep 2,822
Drives: X5M F85
The definitive "which oil" thread X5M X6M
Hi all,
After reading several threads I've come to the conclusion that there is no consensus on general oil viscosity to use. The manual says, 0w40 the inside of the hood says 0w30, Troy Jeup (a S63TU rebulder) recommends 5w50 redline discussed extensively here https://f10.m5post.com/forums/showth...1608382&page=4. From the Manual Viscosity grades When selecting an engine oil, ensure that the engine oil belongs to the viscosity grade SAE 0W-40. As an alternative, you can also use en‐ gine oil with a viscosity grade of SAE 0W-30. I'm leaning towards 0W-40 but we need to come up with a consensus. I only drive about 1k miles a year so I do one change before the winter and one before the summer, looking to do one this weekend. |
05-18-2020, 09:54 PM | #3 |
Rep 1,152
Same boat as you; after reading much of the posts on the F10 M5 forums, 0W-40 if you're in the extreme heat/cold climates. In Southern CA, 5W-40 works.
https://www.stikkitnow.com/0w30-vs-0w40-motor-oil/ As for brands, there's also no consensus. Some guys from M5 forum say less top off with Liqui Moly in between oil changes. I've personally used OEM BMW LL 0W-30 through my dealer, but will try Liqui Moly and see if can go without a top off in between oil changes (usually 5500 - 6K miles). With BMW 0W-30 oil, I top off around 4000-4500 miles after last oil change. |
05-19-2020, 09:01 AM | #4 |
Rep 199
I was told Motul 5w30 specifically for these V8's. Sorry to add to the list...
excu6me on Instagram.
OEM X6M Build |
05-23-2020, 04:18 PM | #5 | |
Rep 1,564
I recently did the valve guide seals on my N63 with 150K miles on it, I removed the heads to lap the valves and decarbonize everything. Pictures below of cylinder walls, Cam journals, and Cams. Very impressed after 150K, Cylinder leak down all within 5%, Valve guides themselves felt new with no play. Below are some pictures highlighting this. Highly recommend this oil & anti-friction combo to all except those in very cold climates. You will notice an immediate smoother idle and running engine. |
Bobby_Drake390.00 CryptoHeff3.00 |
05-23-2020, 05:10 PM | #6 | |
Rep 1,152
Noticed smoother engine once I switched to Liqui Moly 5W-40 vs BMW LL 0W-30. Remains to be seen if I need to top off after 3K miles or so. |
08-31-2020, 09:25 AM | #7 | |
528
Rep 2,822
Drives: X5M F85
Let car run for 5 mins, shutdown Remove Cap from engine bay Remove drain plug After finishing draining, pour a half liter in and let drain to flush Remove and change filter then reinstall Install new plug and crush washer Fill with 9 Quarts and anti friction fluid. Leave 1 quart to be added if needed |
08-31-2020, 10:34 AM | #8 |
Rep 1,007
This is the same issue, people has been talking about in MBWorld for there W211 E63. I have always used Mobil 1 0W-40, and currently have 92K on my E63 and 52K on my X5M. And I don't foresee me changing. As I've had great results using this oil. And I live in the Mid-Atlantic area. The big take away, is that your oil needs to flow thru your engine to lubricate vital engine parts, no matter what environment your in.
08-31-2020, 10:49 AM | #9 | |
Rep 4
08-31-2020, 11:12 AM | #10 | |
528
Rep 2,822
Drives: X5M F85
08-31-2020, 11:19 AM | #11 |
Rep 1,007
Thank you, as I'm new to the X5M, but had a X5 35i before. I'm currently doing my 50K services, already completed the engine coolant, brake flush and power steering flush.
08-31-2020, 11:45 AM | #12 |
IG: @88jae88
1621
Rep 1,734
I run 0-30 or 5-30 OEM BMW oil and from time to time if I need a quart I top off with Mobil 1 5-30 but tbh I've been thinking about changing the type of oil I use for a while and Liqui Moly was #1 on that list because I notice the guys in Europe don't run into as much issues as we do in the states.
So far I haven't really had any issues so I don't want to change something if nothing seems to be wrong but at the same time I rather change it up before anything goes wrong lol.
IM POOR..
08-31-2020, 12:12 PM | #13 |
Rep 1,007
I certainly hear you. Do you let your car warm up a little in the winter months, before driving off? This can certainly, decrease wear issues associated during winter months.
08-31-2020, 02:10 PM | #14 | |
IG: @88jae88
1621
Rep 1,734
Imo the vehicle operates better at warmer temps...which is common sense lol... sometimes I think the dealer tells you fuckery just to destroy your life indirectly all while filling their pockets 😂.
IM POOR..
8202632170.00 |
08-31-2020, 02:16 PM | #15 | |
528
Rep 2,822
Drives: X5M F85
08-31-2020, 02:33 PM | #16 | ||
IG: @88jae88
1621
Rep 1,734
I just really try to stay on top of things and give anything I own the extra TLC it deserves so in case I have to sell it one day the new owner is getting a great product. Even I annoy myself on how meticulous I can be but I like to believe it's for the better.
IM POOR..
08-31-2020, 02:49 PM | #17 |
Rep 1,007
That is exactly what I was referring to, having the engine warm up enough so that the oil can properly circulate thru the engine. I'm only talking maybe 5 mins max, depending how cold it is. Now if it's like 17 degrees, I will let the car run until I start feeling some warmth from the heater.
08-31-2020, 05:05 PM | #18 | |
Rep 1,564
I usually just do a new crush washer, new plug after every 10 or so changes. I add the first 5 liter bottle, then 1.5 cans of the friction additive, then 3.5 more liters as the friction additive replaces 1/2 a liter. |
F85MTuNED1620.50 |
09-02-2020, 10:44 AM | #19 | |
Rep 104
Mobil 1 0W-40 |
11-05-2020, 07:57 PM | #20 |
Rep 38
I recently switched to Liqui Moly 5W-40.
Using bmw twin turbo water thin oil consumption was 1L every 1000km. Dealer said "was normal" I now did over 2000km on Liqui Moly and oil level shows half. So much much better, I will never again use the "recommended" bmw twin turbo oil
Velos stage2 ECU, 3.5" dp, xHP stg3 TCU
11-06-2020, 02:51 PM | #21 | |
Lamininist
82
Rep 1,031
Surely they know best |
11-09-2020, 08:01 AM | #22 |
Rep 1,007
Because thinner oil flows better thru the small passages in the engine, than a thicker weight oil. Think of it in terms of water vs maple syrup, which flows better.
