03-02-2021, 08:13 PM | #45 | |
Rep 42
Blue By You631.00 |
03-04-2021, 09:57 AM | #46 | |
528
Rep 2,822
Drives: X5M F85
03-04-2021, 11:24 AM | #47 |
Self-Deprecating Narcissist
7266
Rep 6,561
Cutting it will make bottoming out more harsh if it is a progressive bump stop. Similar to cutting a progressive suspension spring which will make the ride worse rather than improve.
03-04-2021, 12:49 PM | #48 |
528
Rep 2,822
Drives: X5M F85
Springs and stops are not relative though. Anytime you hit the stops you are going to hear a loud crash. They are progressive not to soften the shock in the cabin but to protect the components. So if you are hitting your stops on smaller bumps you need to raise the height, you'll also be bouncing. Shortening springs has a whole different impact on the suspension behavior as they are constantly under load. Stops are a failsafe, springs are relative to performance management. People cut the stops to increase the throw so the car is only bottoming out under extreme circumstances rather than every bump.
Blue By You631.00 iconoclast7265.50 |
03-05-2021, 08:23 AM | #49 |
7266
Rep 6,561
They are relative if both are designed to be progressive. If it is standard bump stop then cut away all you want. If it is progress I would not recommend. In addition if one is spending nearly $5k on new suspension why cut corners are a $30-50 set of rubber bits? Whenever I install new suspension I swap out all the supporting parts as well so it is dialed in perfectly after corner-balance alignment and I never have to address it again.
05-13-2021, 12:10 AM | #51 | |
Rep 296
09-23-2022, 12:55 AM | #53 |
Rep 501
What did you finally end up doing in regard to springs or Coil overs?
2018 X5M- Black Sapphire Edition
09-23-2022, 06:28 AM | #54 |
Rep 1,252
Atomicteal_M3747.50 |
03-26-2023, 06:46 PM | #55 |
Rep 8
I know this might too old but I would like to give me experience with the H&R VTF Kit. I had similar worries as most people do. I checked post after post looking for answers as I didn't want to spend an arm and a leg.
I ended up getting it installed this past Friday. I live in NYC, I got it done at Tyrolsport in Queens. Qouted price was 900 including alignment. 750 without. Initial thoughts were not good. But I realized the rears were very low. Especially in the rear. So this afternoon it was nice out I jacked up the car and adjusted the leveling lines and by sheer random luck, after I was done the rears sit at 30 1/2 on passenger side fender to floor and 30 1/4 on driver side. The fronts both were at 30 1/5". So I'll adjust them next time when I have time. After the rear were adjusted, it rides like stock to be honest. But a bit taut due to the front stiffer springs. So all those peeps that said don't drop it too low, are correct. I may try to go to 29.3/4" on front and 30 even on rear. And see if that sti works. Good luck to anyone looking for info on this. |
musa421.50 iconoclast7265.50 |
03-28-2023, 02:28 PM | #56 |
Rep 8
Update:
Yesterday, after driving 30 miles to work and 30 miles home, i noticed that at 30"-30 1/2" is probably the lowest you should lower the car - fender to floor measurement. I hit quite a few bumps/road imperfections from Queens into the Cross Bronx Expressway into NJ. Only once it sounded like it bottomed out and had that loud crash that everyone is trying to stay away from. It was a "seam" in the road not a real bump or pothole. it was weird. Its true that it will depend on your roads, and the height you have it set at and what you are comfortable with. The lower you go, the higher chance of getting that bounciness and bottoming out. This generally happened on SPORT + mode when driving. I believe, if i drove in comfort mode, it might have been better, but i may drive home today on COMFORT mode all the way, but need to keep testing on SPORT + to be sure what i am hitting to cause it. Permit me to try to explain a bit: The H&R VTF kit only changes the front springs, not any of the shocks, so the ride will be near identical to stock at the same given height. Of course it might be a slight bit better due to the stiffer springs and slightly lower ride height. It also changes the leveling sensor "rod" that just modifies the signal to raise or lower the airbags. If you set the car on comfort, it should valve the shocks to try to absorb the motions. Set it to SPORT + and it should reduce the vavle opening to 'stiffen' up the ride if im not mistaken. Now the rear shocks are not shorter thus doesnt have the same amount of travel since at the lower or lowest setting, the shock is near or at the bottom of the shock, hence bottoming out or damage if it wasnt for the bump stops. Cutting or installing the M5 short stops helps provide a bit more travel, but only a very small amount. again because the shock body is not shorten. If it was shortened, then lowering to 29" or 28" could be feasible. Here is what i dont know - when car is in comfort mode, does it raise the car? In sport +, does it lower the car? if it does, that could explain why i seem to experience the bottoming out only in sport +. I am using the stock bump stops in the rear. I may replace them with the M5 Comp bump stops and leave the rear at 30 1/2" to prevent a chance to 'bottom" out, since i almost always drive in SPORT + mode. The front should be safer to lower to 29 1/2" with the M5 bump stops. This is prob what i'll do next. Please note, i am not a suspension expert and if someone here is, please feel free to chime in and correct me. Last edited by ture_7; 03-28-2023 at 02:36 PM.. |
shimmy232350.00 |
03-29-2023, 09:08 AM | #57 |
Rep 88
I have the VTFs and I have no issues. My shop that put them in said the rears can be tricky to install and have to be done right for the truck to ride well. I am not a mechanic by any means, so I am not sure what they did different, but I know they had to adjust, take it off the lift, adjust, off the lift several times for the rears. I find the truck rides quite well, not bouncy and feels very planted. I also love the lowered stance.
09-11-2023, 10:50 AM | #58 | |
Rep 465
Are they these ? (VTF adjustable springs for 799 ?) https://www.hrsprings.com/applicatio...s/4/1767/2016/
2008 E88 N54 135i / Cashmere Silver / Beige leather / VRSF catless DP's / BMW Performance Suspension / Whiteline inserts / Aluminum charge pipe and aftermarket BOV |
