04-23-2021, 08:32 AM | #1 |
248
Rep 326
Who's running Methanol injection? Thoughts?
I recently sold my '16 F85 and bought a '17. I transferred all my suspension parts, wheels, as well as my BM3.
I'm adding the JB4 tomorrow and want to order the Methanol Injection kit from Burger MS. I know from my Corvette experience that it can make a huge difference. I'm going to do it, either way, I'd just like the opinions of those who have run with and without it. I'm hoping to see around 700 WHP, if that's possible. Speaking of WHP vs, flywheel HP, what is the generally accepted drivetrain loss percentage on these vehicles?
2021 Individual Grigio Telesto Gray Pearl Metallic X5M C, BC Forged, Dinan tuned, Dinan suspension, MAD Downpipes, Dinan Exhaust. More to come.
Owner, Designer, Tuner- A&A Corvette Superchargers WWW.AACORVETTE.COM |
04-23-2021, 10:35 AM | #2 | |
223
Rep 304
The 8HP75 probably will take that level of power and torque for a while, but I would ramp the boost in at higher RPM in JB4 custom map, and also tune the transmission with XHP and use the 25% line pressure bump. The Tcase is probably suspect, but just be mindful of hard launches. You well know traction+power+weight = broken parts |
04-23-2021, 06:48 PM | #3 |
456
Rep 350
@KLR X5M - Very informative!
I also had thoughts about meth and Pure Turbos upgrade but decided against it. As you well know, breaking anything on our F85 is EXTREMELY costly to fix in terms of parts not to mention the labor. Instead I'm looking for e46 or e92 and planning on going crazy with that project in my home garage. Good luck with your build my friend.
2016 BMW X5M F85 | 2019 - Present
2015 BMW X5 F15 5.0i m-sport | 2016-2019 2001 BMW X5 3.0i Sport | 2005 - 2008 |
04-24-2021, 09:00 AM | #4 |
248
Rep 326
It looks like I'll have to build my own charge pipes to make this work.
I have a great welder/ fabricator that works for me, so it should be doable. As a tuner, engine builder etc. I'm pretty savvy as to how not to break stuff. I outgrew just mashing the throttle and wondering why I left parts strewn across the road many years ago. I think I'll be OK in that regard. Going back to 2006 (that's 9 Corvettes ago for me) I was the first to put a Supercharged 427 C5 R block in a C6. I cut the firewall out and fiberglassed it to clear the FAST manifold. It ultimately made 840 RWHP. Anyone who knows Corvettes knows that the 05 differential was crap. Everyone who breaks one now upgrades to the later Z06 style. I never broke it. The guy who bought it from me blew it to pieces in just a few months. Of course, you never know...
Blue By You631.00 |
04-25-2021, 04:03 PM | #5 |
223
Rep 304
How are you doing the charge pipes since the upper IC housing runs basically to the turbo discharge pipes? Are you doing pre or post IC? I know your background Andy, and have installed one of your sc kits on my friends c6 back in the day. Glad to have a gear head like you on this platform too. If you come up with something crafty on the meth would love to see it.
04-25-2021, 10:56 PM | #6 | |
248
Rep 326
I asked BMS if they had #5 nozzles. If so I think I'll run 2 pre intercoolers and 2 post intercoolers just to test. The tanks look pretty sturdy. I think I'm going to drill and tap them so I can put in 1/4" NPT to 1/8" NPT bushings. I'll use the same adhesive that they glue the Corvette bodies to the frame around the bushing to reinforce it. It will be super strong. Then the 1/8 NPT Meth nozzles will screw right into them. I sometimes see IATs in the 40* range after the intercooler, when spraying a lot of Meth, on a Corvette. If I blow 40*air through an intercooler that is ambient temperature, at best, it's going to warm it up rather than cool it down. This is all hypothetical of course because I have no idea what the air temp/ meth mixture will be before the intercooler. The reason for blowing some of it through is just to atomize it better. I'll probably experiment doing that, then try twin #10 nozzles after the intercooler and see what works best. As you said, you know me and know that I love to experiment and make things better. (or at least try)
04-26-2021, 08:30 PM | #7 |
223
Rep 304
I was going to suggest tapping the IC housing directly. It's a sturdy material as it has to hold up to boost. I've done that npt bung trick with jb weld before too! Are you running the bms FSB and using jb4 for meth management?
04-27-2021, 09:53 AM | #8 | |
248
Rep 326
Yes. I have the BMS stuff on the way, including the FSB. It may not be as fast as some of my Corvettes, but it will surely surprise some kids in their noisy Dodges or Mustangs.
05-07-2021, 12:18 PM | #9 | |
223
Rep 304
05-18-2021, 02:19 PM | #10 |
Rep 1,497
This is for a B58 Supra but still very informative when it comes to meth. This video has me really wanting this same setup on my F15 X5 N55. Just have no clue how much a setup like this would cost.
05-24-2021, 07:14 AM | #11 |
248
Rep 326
I made all new stainless braid PTFE lines for it. I just don't trust those plastic push-in hoses when running 100% Methanol.
Then I made some short custom bushings to screw (and then epoxy) into the intercooler tanks. Standard 1/8" to 1/4" NPT bushings were too long and would have shrouded the nozzles. It looked like it would really mess with the spray pattern. That's as far as I got before we left town. We flew to Boston, about a week ago, and rented a car to drive back to California. My wife and I are visiting some of my dealers along the way. I'll get back on it later next week.
08-31-2022, 03:35 PM | #12 | |
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
