05-10-2017, 01:53 PM | #1 |
318
Rep 203
BPC X5 5.0 DME Tune - +127 WHP / +117 WTQ Gain over factory
Hey guys,
If you were looking at DME tuning options for the N63TU in your X5 5.0, BPC has you covered. We have a great tune that safely adds over 120WHP on the very same motor in a RWD 750i. We do not have a dyno graph for the AWD X5, but judging by the numbers this motor produces in other chassis' That's quite a kick in the pants! Here are some highlights of our tune, and what this means for you as a driver. - We have updated parameters such as boost, fuel & timing maps to optimise power delivery at all points throughout the powerband. - The Valvetronic Maps have been adjusted for better part and wide open throttle response, giving a more direct feel with the car. - Exhaust valves are open all the time in sport and sport + modes, giving the car a sporty sound while performance driving yet the ability to quiet it back down again in normal driving modes. - Rev limiters are the same unless requested to be bumped to 7200rpm - Cold start and cat disable on stage 2 off road tune can be enabled - Speed limiter is removed - If requested, we can unlock for bootmod 3 Supported Models 2013 - 2016 750i 750li (F01, F02) 2013 - 2018 650i (F12, F13) & 650i grand coupe (F06) 2013 - 2017 550i & 550i GT (F10) 2013 - 2018 X5 5.0 (F15) The following graph and numbers were produced on a 750i RWD car. The X5 being all wheel drive will output slightly less power but the motor is still increasing by this much from where it currently is! FACTORY 348 WHP / 397 WTQ Stage I 475 WHP / 514 QTQ +127 WHP / +117 WTQ Gain over factory DME Tuning Procedure This vehicle is tuned by Bench flashing the DME only. This requires the DME to be removed, and sent in for software modification and mailed back. If you are interested in purchasing a tune from us, please visit our website to order: https://bimmer-performance-center.my...tune-2013-2016 If you have any questions you may also PM me and I'll be sure to answer back. Thank you, John |
