02-21-2022, 11:56 AM | #1 |
Rep 627
Drives: X5 F15 M package
Gas level wrong
Gas level is showing 1/4 despite tank being full.
Tried to read any error code unsuccessful. Any ideas? |
02-21-2022, 12:41 PM | #2 |
Rep 660
Sounds possible that you have a faulty fuel level sending unit. The diesels have one on each side of the tank would image gas is similar. While I don't think it's common for them to go south, I have read others having them replaced.
02-21-2022, 03:30 PM | #3 |
Rep 475
Curious .... what does your miles to empty report? Does it report like its a full tank or 1/4?
02-21-2022, 03:31 PM | #4 |
Rep 627
1/4 like 80 miles.
Florida-X3264.50 |
02-21-2022, 03:49 PM | #5 |
Rep 475
02-21-2022, 09:15 PM | #6 |
150
Rep 349
Having the same problem after buying my X5 used - I pulled the rear seat on my e70 to access the sending units. Then, I pulled the connectors and cleaned the contacts with Contact Cleaner.
Been Good ever since. |
03-05-2022, 12:25 PM | #7 | |
Rep 627
Thank you |
03-05-2022, 04:20 PM | #9 | |
Rep 627
I think f15 is a bit different than prior version and I have the third row as well. Also took a trip a few days ago until gas said 0 then went to a gas station a few steps away. The indicator ended up showing "- - -" for the mileage. I presume the fuel pumps are fine and it's really the one of the sensor as you said. |
