04-16-2020, 12:39 AM | #1 |
Rep 9
Floor Jack to Jack Stands?
Looking for help on how to best use a floor jack to lift the F85 X5M to get it up on 4 jack stand at the jack points.
I've looked at the F15 forums which say that the F15 can be lifted in the front center point and the rear center on the differential. Does that apply to the F85 as well? Thanks! |
04-16-2020, 06:18 AM | #2 |
Rep 639
I'd like to know too, but I've never been able to find a center jack point. Looking through the manual too, haven't found it as it only references the 4 side lift points...
04-18-2020, 11:23 AM | #4 |
Rep 639
Don't jack the diff under any circumstance, it's not meant for that.
04-18-2020, 12:01 PM | #5 | |
Rep 546
Used a piece a plywood under diff (not to touch the seal) and there is a jack point in the center front that you have to remove an under panel. My vehicle was like this for about 3 months while I got my wheels back. I left the jack on the whole time to add support. No issues. |
04-18-2020, 07:34 PM | #6 |
170
Rep 340
Drives: Several
Garage List 2004 Ferrari 360 Sp ... [0.00]
2015 Ford F150 Lari ... [0.00] 2015 Porsche GT3 [0.00] 2017 BMW X5M [0.00] 2020 BMW X7 M50i [0.00] |
Try jackpoint jackstands. Or even consider the quickjack lift?
http://www.jackpointjackstands.com/home.html Us Porsche guys swear by them
2023 GMC Denali Ultimate
2021 Porsche Cayenne GTS 2019 Ford Raptor SuperCrew 2015 Porsche GT3 2004 Ferrari 360 Spider 6M |
04-27-2020, 12:16 AM | #7 | |
Rep 198
http://f15.bimmerpost.com/forums/sho....php?t=1693288 |
05-04-2020, 11:54 AM | #8 |
528
Rep 2,822
Drives: X5M F85
I use this jack point extensively, with protection of a 8" piece of pine 1x4.
11-16-2020, 08:57 PM | #9 |
Rep 104
11-17-2020, 10:05 AM | #10 |
Rep 1,011
I wouldn't recommend jacking up your X5M/X6M from the Rear Diff Cooling Fins. Their is a risk of them breaking off, and cracking your rear differential, which would be a very expensive repair.
I would use the (4) jacking points, one on each corner of the vehicle to do this. |
11-17-2020, 02:45 PM | #11 | |
199
Rep 363
11-18-2020, 08:54 AM | #12 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
I use a floor jack and the front center jack point to get the front high enough to lower down onto jack stands on the front side jack points.
Then there's just enough room to get the floor jack under the rear bumper to the rear diff, on the housing, never on the cover, to lift the rear high enough to get the jack stands under the side rear lift points. It's a little time consuming, but it works. I've been contemplating getting two or four of these UniJacks, combo bottle jack and jack stand to get it up in the air a little more easily.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
