11-19-2020, 10:24 PM | #1 |
Rep 685
Drives: 06 Black Sapphire Z4MR
Dash Cam switched 12v?
I have tried every single 12v fuse, tried the steering wheel adjust fuse. Yet they all seem to be permanent.
They all keep my camera running, even if I leave the car and lock the door... Am I missing something? Every other cars I have owned I could just plug a fuse tap to a 12v and my dash cam will figure out to shut down in its own when engine power is off, and come on with ignition. Is there actually a properly switched 12v? Or do I have to unplug it every single time which is fine for my front camera, it'd be far more difficult for my trunk camera Any help would be appreciated
Revolution of our Times
I will return to the track, one day. |
11-19-2020, 11:50 PM | #3 |
Rep 5
I use a power cable that plugs directly into the ODB port. Works great with my dash camera and there is a switch on the unit which is defaulted to run for 5 minutes after the car is turned off. There is a mini-usb and a micro-usb option available. Search for Rearmaster Universal OBD Power Cable in Amazon.
11-20-2020, 01:29 AM | #4 |
Rep 131
You should download the installation manual for BMW ADVANCED CAR EYE 2. It shows the front + rear fuse box re installation on various BMW Models.
11-20-2020, 07:58 AM | #6 | |
Rep 685
Others have said the 12v socket does shut down after 10 minutes after locking the door, I tried that before but it almost left my battery flat and trying not to do that. So a proper 12v that actually stops when the engine stops would be good
11-20-2020, 09:55 AM | #7 | |
147
Rep 334
The whole point of the AUX battery is to handle the load while the engine is NOT running. Ignition in position 1 or off is a different story, but as mentioned, it seems like most branch circuits lose power after 5-10 minutes |
11-23-2020, 03:06 PM | #8 |
Rep 4
11-23-2020, 07:37 PM | #9 | |
<3 Flat Four
215
Rep 754
as with most european vehicles, accessory power is kept on for roughly 10-15mins after the vehicle is shut off there is no reason one cant tap into any of these switched power to feed the switched source the dash cam needs
2011 335is Le Mans Blue
11-27-2020, 09:54 AM | #10 | |
Rep 685
11-29-2020, 01:21 AM | #11 |
Rep 536
I have tapped into the rear view mirror housing which had a cable that was powered on only. Check the forums for radar detector installs and you will find it.
Present: 2014 X5 50i
