11-07-2024, 01:07 PM | #1 |
Rep 31
Front Camber Issue? *Pics*
So my front tires, the inner tread is brand spanking new, not even the “S” on the DWS has worn off yet.
Yet the outer rib is completely gone down to the ply. This is after 2-3 years about 40k miles. I heard you can’t adjust the front cambers on our cars (X5 F15), is there a new steering knuckle or strut plate I can buy to adjust the camber? Or is my issue something else completely? |
11-07-2024, 01:21 PM | #2 |
Rep 743
Yup, that's normal. No way to adjust with stock suspension. FCEuro sells a control arm kit to dial-in negative camber.
Another fix that I've been using is bumping the front tire pressures 2-3 extra PSI. I'm at 20K on current set with minimal feathering or visible outer wear. |
11-07-2024, 01:46 PM | #3 |
Rep 241
I'm sure there'll be differing opinions, but my interpretation of that wear pattern would be toe or camber, so I'd do an alignment to confirm before spending more on it.
11-07-2024, 01:49 PM | #4 | |
Rep 19
https://www.bimmerworld.com/Suspensi...126863785.html |
11-07-2024, 02:24 PM | #6 |
Rep 743
Camber is not adjustable on the fronts with the F15 platform. Agree that toe is another possible culprit, but regardless, positive camber is a known out of the box issue on the F15s.
