      07-07-2021, 05:02 PM   #287
Franktea1$
Franktea1$'s Avatar
Drives: BMW e39 540 sport & BMW X5M
This may fix this problem, X5 M, X6 M UPDATE TO MODIFIED BRAKE PADS NO
ADHESIVE. see attached.
      07-08-2021, 12:47 AM   #288
Slickrick2
Slickrick2's Avatar
Drives: 2018-X5M-BLK Sapphire Edition
It's a temporary fix. The Squeal will come back. I know it happened to me after they replaced the brake pads with the updated bulletin pads. I was able to get the front rotors replaced and a new set of brake pads. (LONG STORY) If you search my name you find the info on what happened. In short I was able to get my rotors replaced out of warranty at no cost to me.
Regardless, they occasionally Squeal even though I have the new Rotors and Brake Pads. It took a few months but it does squeal when the wheels get dirty or hot from stop and go braking. A good cleaning helps and lasts but it comes back.
It if gets unbearable then I'll switch the brake pads to the one the group has been recommending.
2018 X5M- Black Sapphire Edition
      07-08-2021, 07:44 AM   #289
Blue By You
Blue By You's Avatar
631
Drives: 2017 LBB X5M F85
Brochure
My dealership actually gave me a special M brochure addressing big brakes and squeal when they replaced my rotors and pads. Seems like they're hedging the issue of people complaining about brake squeal...
      07-08-2021, 09:23 AM   #290
Franktea1$
Franktea1$'s Avatar
I'll continue with the squeal for now, when the pads are done i'll review these posts again and make a decision which way to go.
      07-12-2021, 12:11 PM   #291
Slickrick2
Slickrick2's Avatar
They are trying to justify it. They should not squeal like that. I wonder if it's happening with the new M versions?
      07-12-2021, 12:47 PM   #292
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
I had my mechanic apply this black anti-squeal liquid directly to my front pads. This liquid soaks into the pad, and my squeal was history. I'm currently using Power Stop Carbon Ceramics on the X5M. When we removed the calipers, the pads showed rust on their surface. So I knew then where the squealing was coming from. It's been a months now, and no noise or squeals. And I have to tell you, that I love it. The liquid comes in a little white bottle, but looks white out. But applies like a big fat magic marker. When applied, it needs to setup from a 5 minutes to soak in, then reinstall. Good news a little web search, and I found it, it's BG Stop Squeal.
https://www.amazon.com/BG-STOP-SQUEA...23028961&psc=1
      07-12-2021, 08:40 PM   #293
Klienfeld303
Klienfeld303's Avatar
Drives: 2018 x5 M
https://www.amazon.com/BG-STOP-SQUEA...8961&psc=1
I went to power stop and never squealed again. 🤷🏽
ACID.
      07-13-2021, 06:12 AM   #294
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
I am using Power Stop Carbon Ceramics, but still had brake squeal. My mechanic thinks that since I wash my F85 very often, that I inadvertently washed the Stop Squeal away using the pressure washer to clean my wheels and calipers. And, I think that he has a point, I do apply the cleaner and a wheel brush to clean the wheels, and spray pressurized water all up in there. But, now that a new fresh coating of BG Stop Squeal has been applied, no noise or squeal and I'm aware of my shortcomings now. So now, I use just a spray bottle and wheel brush and the pressure washer on a very low setting, with a different spray nozzle attachment.
      07-27-2021, 06:34 AM   #295
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
I'm running the Z23 pads from Power Stop and mine is only 1/4"
      07-27-2021, 08:36 AM   #296
640ijims
Drives: 2018 X5M , 14%E2%80%99640i ver
2018 X5///M  [7.50]
2018 BMW  [0.00]
Is the product "Stop Squeal" by b&g?
      07-27-2021, 08:43 AM   #297
m3fuz
199
Drives: 17 X5M, 19 X3 30i, 03 C4S
Yep - there’s an Amazon link a few posts up.
      07-27-2021, 09:18 AM   #298
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
Yes, that it what my mechanic applied to my pads, he then lets it sit for 5 mins to sink into the pads before their installed. And I can tell from experience this shit works.
I was getting a light squeal even with carbon ceramics, when we removed my pads, he told me that I washed off the application by pressure washing my vehicle and wheels too much.
He was absolutely right.
      07-29-2021, 01:46 PM   #299
swift
Drives: 2017 X5 M
Just found this thread, and wanted post my results. I had terrible squeal on a new to me 2017. I went with these pads from Rock Auto. ~160 and still no squealing after 6 weeks. I changed out pads only. I started with just the fronts and it completely eliminated the squeal. I changed the rears to be consistent. If they start squealing in the future, I'll just change them out again. $92 for the fronts a great deal. BTW: These are the largest pads I've ever seen.
POWER STOP Z231738 (Z23-1738)
POWER STOP Z23919B (Z23-919B)
      07-29-2021, 04:57 PM   #300
Klienfeld303
Drives: 2018 x5 M
I forgot to mention - I have a brand new, unused set of ceramics for the factory f85 rear calipers for sale. 75 bucks?
ACID.
      07-29-2021, 06:33 PM   #301
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
It's not like you need them anymore, as we both have different rear calipers now.
      08-12-2021, 12:43 AM   #302
Sleepr72
Sleepr72's Avatar
Australia
4
Drives: 2016 BMW X5M Donnington Gray
Originally Posted by Pronga38 View Post
Thanks Sleepr72, I just picked up my 16 F85 a few weeks ago and also being based in Melbourne have found getting multiple parts, including Rotors & Pads, difficult.
I'll go with your recommendation on the EBC Yellowstuff pads - I trust there's been no performance issues?
Pronga38 No performance issues to speak of. I've had the Yellowstuff pads all round in for a little over a year now and 5,000 Kms. Overall they are ok in every way. They brake well (better than OEM), inital bite is also ok. I don't drive all that hard but I do push it every now and then and they haven't let me down. Haven't been able to get any brake fade either (maybe I'm not trying hard enough!!!)
But... brake dust is still an issue, not as bad as OEM, but not far from it. The squeal is also still evident which is really annoying, mainly at low speeds and when coming to a halt.
Cheers,
Chris.
///M
      08-12-2021, 09:42 AM   #303
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
You may find this odd, but I do not get any squeaks moving forward, but when I back up they squeak. Which I find extremely odd.
      08-29-2021, 09:27 PM   #304
ekological
Drives: 2002 M5
Finally swapped in the powerstop front pads. I didn't bother with sanding the rotor. Cleaned the wheel barrel which was completely caked in brake dust. Buttoned everything back together and took it for a ride to bed in. Did a few high speed stops and it wasn't long before they faded. Yeah....not a track pad, but hopefully the decrease in dust and supposed friendliness to rotors outweighs repeat stop performance. Looking forward to seeing how these play out.
      08-30-2021, 07:07 AM   #305
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
As the pads are bedded in more, it gets better.
      09-01-2021, 07:30 PM   #306
MrSmoothEM3
MrSmoothEM3's Avatar
23
Drives: E92M3, E60 M5, F10 M5, F85 X5M
2016 BMW X5M  [0.00]
Do you have the fronts as well?
      09-01-2021, 07:47 PM   #307
ekological
Drives: 2002 M5
Just pick them up at RockAuto for $91 + shipping. I have a set of new rears that I would sell for $50. I have the Panamera rear caliper upgrade with powerstops for those calipers, so I won't be installing them. I can also help out with the install if you're willing to drive to 8A off of the NJTP.
      09-03-2021, 09:45 AM   #308
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
The Porsche Panamera 4-piston rear calipers, is a very simple and easy install. I'm glad that I purchased them, besides they look 100% better, and add additional braking force for a 5000+ lbs. vehicle
