07-18-2008, 07:39 AM | #23 |
Rep 10,176
On your front shock towers, you'll see three nuts that are fastened to each strut hat. In addition to the three threaded studs that pop out of the strut hat, there's the alignment pin, that simply protrudes through the shock towers, and are immediately evident, once you open your hood.
Here's a diagram of the strut hat, where I circled the alignment pin. |
07-18-2008, 10:28 AM | #25 |
Rep 6,760
On my E46 I had to do an alignment after this, because the toe angles were messed up after moving the suspension.
Is this not necessary on the 1?
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
07-18-2008, 11:59 PM | #26 |
Rep 29
Has anyone installed an
H&R Triple C Eccentric Systems Precise camber settings are an integral part of any performance suspension. H&R’s Triple C Eccentric System uses a pair of specially-designed eccentric bolts that replace the original upper fastening bolts on all McPherson strut applications with bracket fixation. A simple turn of the bolts allows adjustments of +/-3 degrees for precise camber settings. In Germany, the supplied TÜV certificate makes the individual homologation of the H&R Eccentric System a snap. H&R Triple C Eccentric Systems Precise camber settings are an integral part of any performance suspension. H&R’s Triple C Eccentric System uses a pair of specially-designed eccentric bolts that replace the original upper fastening bolts on all McPherson strut applications with bracket fixation. A simple turn of the bolts allows adjustments of +/-3 degrees for precise camber settings. In Germany, the supplied TÜV certificate makes the individual homologation of the H&R Eccentric System a snap. H&R Triple C Eccentric Systems Precise camber settings are an integral part of any performance suspension. H&R’s Triple C Eccentric System uses a pair of specially-designed eccentric bolts that replace the original upper fastening bolts on all McPherson strut applications with bracket fixation. A simple turn of the bolts allows adjustments of +/-3 degrees for precise camber settings. In Germany, the supplied TÜV certificate makes the individual homologation of the H&R Eccentric System a snap. H&R Triple C Eccentric Systems Precise camber settings are an integral part of any performance suspension. H&R’s Triple C Eccentric System uses a pair of specially-designed eccentric bolts that replace the original upper fastening bolts on all McPherson strut applications with bracket fixation. A simple turn of the bolts allows adjustments of +/-3 degrees for precise camber settings. In Germany, the supplied TÜV certificate makes the individual homologation of the H&R Eccentric System a snap. H&R Triple C Eccentric Systems Precise camber settings are an integral part of any performance suspension. H&R’s Triple C Eccentric System uses a pair of specially-designed eccentric bolts that replace the original upper fastening bolts on all McPherson strut applications with bracket fixation. A simple turn of the bolts allows adjustments of +/-3 degrees for precise camber settings. In Germany, the supplied TÜV certificate makes the individual homologation of the H&R Eccentric System a snap. H&R Triple C Eccentric Systems Precise camber settings are an integral part of any performance suspension. H&R’s Triple C Eccentric System uses a pair of specially-designed eccentric bolts that replace the original upper fastening bolts on all McPherson strut applications with bracket fixation. A simple turn of the bolts allows adjustments of +/-3 degrees for precise camber settings. In Germany, the supplied TÜV certificate makes the individual homologation of the H&R Eccentric System a snap. |
07-19-2008, 08:00 AM | #27 |
Rep 17
How much of an affect does lowering have on the suspension geometry of these cars? I ask because on my car for example anything lower than 1/2 an in. starts to point the control arms north. Not so sure about rwd but in fwd and awd that means torque steer. Specially on these new Vws
07-19-2008, 08:16 AM | #28 | |
Rep 10,176
I know of people that have shimmed their e36 M3, that does what those bolts do. The main problem is that it allows the wheels to cant in towards the strut, almost requiring spacers (or larger spacers if you're already running with spacers). Camber plates move the entire strut inward, neither increasing or decreasing the gap between the tire and the strut/spring. It can also change the geometry of how the strut was designed to compress. Camber plates do not do that either. |
07-19-2008, 10:26 AM | #29 |
Rep 29
H&R Triple C Eccentric Systems -negative camber
So this means that the bolts either:
1. can`t be installed, 2. or they will not provide enough negative camber to help reduce the understeer or 3. camber plates are the only solution to get neutral handling at the track? |
07-19-2008, 12:58 PM | #30 |
Rep 6,760
Another trick that was done on the E46: exchange left and right strut tower aluminum hats (while rotating them 180 degrees to fit the holes).
I think this was good for around 1.5 degrees.
07-19-2008, 07:08 PM | #31 |
13
Rep 356
07-20-2008, 01:50 AM | #33 | |||
Rep 1,565
We've run KW's on all of our cars since 2005, they're yet to let me down. Quote:
The Clubsports are a high end coilover. For how fast we can go on street tires, the V3's are plenty. The Clubsports have more adjustability and are a "faster" setup, but you have to be a good enough of a driver/engineer to set them up properly. So you are talking at least 1 full day of testing to get it right. I don't have any personal experience with TCKline, but it looks great. So can't really comment. Quote:
Here's our rear sway going in. As you can see, the rear subframe is lowered a few inches. There's lots of crap down there. Burlington - some cars have the strut mounted to the hubs via a clevis. Having a slotted clevis or eccentric bolts, as you add negative camber, your wheel gets closer to the strut. Larry's correct, they are round and centered. Swapping from L to R won't do anything. |
09-05-2008, 07:16 PM | #34 |
Rep 1,657
can anyone post pics for this DIY? Thanks. Also, would this cause problems with tire wear?
"KOPEYKA" /// Titanium Silver / Black Leather / Gray Poplar / Sport Package / Premium Package / 6MT / Feb 08 Production |
09-06-2008, 06:37 PM | #35 |
Rep 138
Alright, for those of you that wondered like I did, I just did the alignment pin removal and it was very easy. I posted a DIY in the DIY section but I took the pictures afterwards, mostly of the general area, so people know where the pin is that is to be removed.
http://www.1addicts.com/forums/showthread.php?t=15571 |
09-08-2008, 08:32 PM | #36 |
AutoXer
34
Rep 683
If you change the camber on a BMW, it will change the toe on the 1 or the 3, or any other strut suspension. More negative camber will get you more toe out or less toe in.
