      04-20-2016, 01:14 PM   #1
citznfish
Drives: 2016 X5 M Sport w/20" wheels
Can the X5 235i M sport do a burn out?
I tried and failed.
Traction systems off. Tried power braking it to get the rear wheels to spin. nada.
      04-20-2016, 01:35 PM   #2
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
It will be pretty difficult since it is all wheel drive..
also 35i, not 235i
      04-20-2016, 02:41 PM   #3
citznfish
also 35i, not 235i
Oooh, I should clarify. I have the sDrive.
      04-20-2016, 02:46 PM   #4
Kzang
Kzang's Avatar
3240
Well in that case.... It shouldn't be hard. Shifter to the left, put in sport and turn off traction. Hold brakes and Rev em up. Have you tried Launch control? Not sure if this would help since technically this feature is suppose to help you take off quickly, so that means without spinning the wheels.
On my xDrive, I was able to loosen up the rear wheels several time and it actually barked a few times as well. I also have MPPK and Racechip tune installed for more power though.
      04-20-2016, 04:57 PM   #5
citznfish
That's what I tried. Never had a vehicle that couldn't do a burnout, but i also never owned an SUV before.
I haven't tried launch control because the manual stated that the car needs 1200 miles on it before attempting to use it the first time. I definitely do plan on trying out this feature.
I may look into the tuning.
Thanks!
      04-20-2016, 06:52 PM   #6
Stinkyxy
Drives: X5
If you are hesitant to do launch control before 1200 miles You may want to put a burnout into that category as well.
      04-20-2016, 10:41 PM   #7
sgtpeper
Drives: '16 X5d M-Sport DHP
Do all X5s have launch control? I thought just Ms got that?
Jeff
'19 Jaguar I-Pace First Edition
'17 Volvo XC90 T6 Inscription
'03 Porsche 996 Turbo X50
      04-20-2016, 11:27 PM   #8
Chem14
170
Drives: 2018 530e
No, but all can have launch control via coding.
      04-21-2016, 07:36 AM   #9
TortugaX5
Drives: 2016 F15 X5 X35i
Really? I didn't know that
      04-21-2016, 08:14 AM   #10
Chem14
170
Drives: 2018 530e
Yes. I have X-line and coded launch control and sport+.
      04-21-2016, 01:13 PM   #11
Tyler_Durden
Drives: Alpine white X5 35i
Are the instructions in the coding thread? I don't I have seen that
      04-21-2016, 01:20 PM   #12
Neuera09
Did your steering wheel come with paddle shifters? Another forum member had problems adding 2TB in his FA for the Sport+ feature.
      04-21-2016, 01:25 PM   #13
Kzang
Kzang's Avatar
3240
Paddle shifters are only standard on Msport cars. Unfortunately, that can't be coded However.. you can purchase one and install it and then code it to work.
      04-21-2016, 02:05 PM   #14
alphaod
alphaod's Avatar
What's interesting is I have Luxury, coded, but I still don't see LC and Sport+ modes.
      04-21-2016, 02:13 PM   #15
Neuera09
He probably replaced his stock steering with an msport steering. That's the only thing I can think of.
      04-21-2016, 02:15 PM   #16
Neuera09
BTW, I coded SAT and launch control on my xline.
      04-21-2016, 05:39 PM   #17
Chem14
170
Drives: 2018 530e
Yes they are in the coding thread. They may be buried in there. Opasha tested the code on my car.
      04-21-2016, 05:40 PM   #18
Chem14
170
Drives: 2018 530e
You should have it if you did the coding.
      04-21-2016, 05:41 PM   #19
Chem14
170
Drives: 2018 530e
No. Stock steering wheel.
      04-21-2016, 05:43 PM   #20
Neuera09
How'd you do it Chem? One of our members are getting all sorts of errors. Please enlighten us.
      04-21-2016, 05:45 PM   #21
Chem14
170
Drives: 2018 530e
No. Stock as I mentioned above. Yes we had issues initially with this as well. The Sport+ would show up in my extended display screen but we couldn't select it. If I get a chance I will dig up the thread and let you know what we did. Its been about a year since we went through the troubleshooting.
      04-21-2016, 05:47 PM   #22
Neuera09
Thanks man!
