06-20-2020, 03:25 PM | #5149 |
Rep 51
Newbie coding question about CAFD files in a newly installed hitch (aag) module: in ESYS I noticed the aag module currently has no CAFD file. Can I inject the file by coding the module (right click > code) using psdzdata lite or do I have to flash it (using the full psdzdata)?
06-20-2020, 04:44 PM | #5150 |
Rep 51
OK so actually I used some different search terms and it looks like the procedure to inject a CAFD is:
Connect => Read FA (VO) => Activate FA (VO) => Read ECU(VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD matching from latest I-Level Shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. I'll give this a shot. [EDIT] - this worked brilliantly! Last edited by TheMane; 06-20-2020 at 08:48 PM.. |
screaminfast143.50 |
07-03-2020, 10:10 AM | #5151 |
Rep 439
Drives: 07 E92 335 / 17 F16 X6 35i
Anyone know if you can code european hazards on F-series cars? I had done it on my e92.
@mikecentola
07 335i SG / CR - LOTS OF MODS - BUILD THREAD 17 X6 SG / LCSW - ZMM/ZCW/ZDA/ZDB/ZLP/ZPP/MPPK - H&R VTR / Vossen 22x10.5/22x12 18 Ford Raptor |
07-07-2020, 07:37 AM | #5154 |
Rep 4
Can I get a link to this as well?
07-10-2020, 05:45 PM | #5155 |
Rep 8
Hi all, I emailed tokenmaster (twice) over the last week with a copy of the donation I made to a local charity (children's hospital) and had no reply, anyone know how else I can get this coding software?
thanks for any help Austin |
07-10-2020, 05:48 PM | #5156 |
Rep 5
Accidentally Coded DME HELP
Hello guys,
I own a X5 F15. I accidentally coded the DME CAFD file, didn't chage anything, I just inadvertently right clicked on it and then clicked on code. I'm worried because the program prompted a window at the end with one error. Car seems fine, it showed ESP and P Brake warning but after ignition off and on no warnings and the car runs with no apparent problems. Should I be worried? https://f15.bimmerpost.com/forums/sh....php?t=1738309 Last edited by kikocarv; 07-10-2020 at 05:50 PM.. Reason: Correction |
07-21-2020, 04:42 PM | #5158 |
Rep 2,511
07-27-2020, 07:21 PM | #5159 |
Rep 439
Just finished coding my wife's 2014 and my 2016. Couple things to note... My software was just updated at the dealer to the latest so I needed the 4.24.12 software for it to read the CAFD files.
On the x5 I was able to add 2TB (SPORT+), Fold Mirrors, HUD Turn Signals, Digital Speedo, Video in Motion, Warnings removed, VLD, Fogs whenever, and Rolls Royce chimes. On the X6, however, the modules and coding were different. I was still able to do almost all of the HU_NBT2 stuff; did the digital speedo, VLD, fogs whenever, and rolls royce chimes, but there were no options in HKFM to close the trunk, HUD turnsignals didn't work because I have 6WB (as the cheat sheet said), and a couple other things were already set from the factory like bright DRL's, NAVI_AUTOZOOM, and TCM_LOGIC_R_OFF_DOOR. Also on either car, I wasn't able to get KOMBI/HUD logo changed to anything but BMW. (DKOMBI with 6WB). I may spend some time with Google Translator to see what else I can decipher.
@mikecentola
07-28-2020, 10:26 AM | #5160 |
Rep 11
Anyone finding that some settings conflict with others?
I'm seeing that coding some settings, for example, shutoff radio/nav conflicts with the comfort access "close windows and mirrors with FOB". When I set this, unless the radio/nav is on, the fob wont work. Anyone have a definitive list of conflicts like this?
07-28-2020, 10:29 AM | #5161 | |
Rep 11
07-28-2020, 10:39 AM | #5162 |
Rep 439
I might remake the F15 cheat sheet spreadsheet with tabs for older vs newer modules and known good stuff.
@mikecentola
07-28-2020, 10:40 AM | #5163 | |
Rep 11
I've often found errors are related to timeouts. Usually happens when the system partially shuts down. Make sure before you code that the system is "on" and you have a fresh connection. |
07-28-2020, 10:42 AM | #5164 |
Rep 11
Don't bother. Just go buy ESYSX. It works just as great and you'll get instant response.
07-28-2020, 10:47 AM | #5165 |
Rep 11
That would be super helpful. I'll upload what I'm currently using...which is largely based on Almaretto's version. I did find that the close mirrors/roof/windows didn't work in Almaretto's original version so found the right settings to add. Also found that the 'Engine Start/stop with no brake' setting actually causes the X5 to not start at all lol. Good reason to make sure you backup your CAFD's before starting coding
07-28-2020, 12:06 PM | #5166 |
"Salud"
13791
Rep 4,668
Drives: F01 & F15 / Mineral White
08-06-2020, 10:10 PM | #5167 |
Rep 1,179
Has anyone changed the oil change interval via coding? I'm wanting to start changing the oil at 5k miles instead of the typical (10k ?) mileage default value. I've found a couple of threads that sort of address doing this but don't give any specifics.
https://www.m3post.com/forums/showthread.php?t=1272556 https://www.bimmerfest.com/forums/sh....php?t=1021833 |
08-07-2020, 09:46 AM | #5168 | |
Rep 545
Drives: 2018 M5 / 2011 X5 35d
08-07-2020, 12:11 PM | #5169 |
Rep 23
For VLD on F15. Is it just to remove 8S4 and VO code the relevant tree. I have xenon adaptive and did some FDL coding, now it does move sideways when I steer but not sure if the beam changes vertically depending on speed. Would that work only if you remove 8S4?
08-07-2020, 12:56 PM | #5170 | ||
Rep 2,511
