07-02-2020, 11:00 PM | #1 |
Rep 34
Rolls Royce startup on X5 2014 (F15)
While coding my X5 original startup logo I found a few there so I tried one of them. Rolls Royce one was pretty cool. I switched myin from original to M logo. I have a 2014 X5 xLine.
Rolls Royce logo: M logo: |
07-02-2020, 11:10 PM | #2 |
Rep 97
I have Rolls Royce chime set (instead of annoying original X5 one). Sounds a bit like old Windows 7 sounds. Much less obtrusive and annoying. Did it back in 2017 via carly obd-II.
07-02-2020, 11:15 PM | #3 |
Rep 34
Yeah it's pretty great but I feel like the colors are a little sketchy but looks great. I changed my ambient lighting color to red and set the M logo. They go great together. I'm using Bimmercode and Veepeak OBDii.
07-02-2020, 11:23 PM | #4 |
Rep 97
Do you know by any chance if our cars can be coded to have that rear stop lights blinking fast when we hit the brakes from higher speeds? It's kinda cool and alerts rear drivers. I tried to code it via Carly, but I wasn't successful. Not even sure it can be done without extra hardware.
Swati0126.00 |
07-02-2020, 11:27 PM | #5 | |
Rep 34
Picasso37.00 |
07-02-2020, 11:34 PM | #6 | |
658
Rep 345
Swati0126.00 |
07-02-2020, 11:58 PM | #9 | |
Rep 34
07-03-2020, 06:36 AM | #10 | |
Rep 131
Swati0126.00 |
07-03-2020, 12:32 PM | #13 |
Rep 2,511
07-03-2020, 04:44 PM | #14 | |
Rep 162
BM
07-03-2020, 05:23 PM | #15 | |
Rep 627
Drives: X5 F15 M package
Swati0126.00 |
07-06-2020, 11:36 AM | #16 | ||||
Rep 7,480
So for those that have coded this feature on but you’re not sure if it works...it may be due to some of your other coding selections like not driving fast enough...and not braking hard enough. Just a thought.
Swati0126.00 |
07-07-2020, 06:58 PM | #18 |
Rep 7,480
And another coding issue some may run into with the BRAKE FORCE “flashing” is...depending on your build date and communication bus modules...you may need to go to more than one module to code the flashing.
I believe if you only have the FRM (footwell module)...all the coding is done in that one module. But latter build models that have the FEM (front electronics module) and REM (rear electronics module)...you need to do coding in BOTH of those modules in order to initiate the flashing brake force lights. Below is an example when using Bimmercode...if you have the FEM & REM...you have to code TWO modules to initiate this feature:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 07-07-2020 at 07:09 PM.. |
07-08-2020, 10:56 AM | #19 |
Rep 2,703
07-08-2020, 02:59 PM | #20 |
Rep 1,179
I actually tried the rolls sounds at first and they were a little better. I ended up using the i8 sounds after all because they're really low key and not bothersome.
09-04-2020, 02:11 AM | #21 | |
Rep 3
