03-12-2019, 06:23 PM | #1167 |
Rep 196
My 15' does not display whether the heated steering wheel has been turned on or off. I guess the early models didn't.
I found this code digging around, supposedly to have an icon appear either on the dash or HUD. Anyone tired this or know if it works before I bother. Thanks
2015 X5 35d M sport
2017 340i M sport 1991 M5 1988 M5 |
03-12-2019, 10:07 PM | #1168 | |
Rep 8,364
03-12-2019, 10:25 PM | #1169 | |
Rep 1,343
03-12-2019, 11:44 PM | #1170 |
Rep 196
From what I read, BimmerCode.
I'm ok with it just being on the dash. it's just terribly annoying making sure i pressed the button. I'll try it tonight. See what happens.
2015 X5 35d M sport
03-13-2019, 11:14 AM | #1171 |
Rep 196
Just wanted to confirm it does work. Press the Button and on the bottom of the dash "steering wheel heater activated" and deactivated. Just like every other car does..
2015 X5 35d M sport
03-16-2019, 08:05 AM | #1174 |
Rep 196
Never found this annoying until I tried hooking up a trailer.
With the door open, I put it in drive/reverse to adjust slightly to line up to the trailer but it throws it back into park because the door is open and says to secure vehicle blah blah Anyway to code this out? Couldn't find it on the cheat sheet. Thanks
2015 X5 35d M sport
03-16-2019, 11:05 AM | #1175 | ||
Rep 885
- BDC > Expert Mode > search for line 3070 - Within 3070 > scroll down to the desired Ensamble which will have up to 10 layers below it, F15 utilizes only the first 3 - Example I changed my last 3 Ensembles as I was not using those color patterns, Layer 1 will be top led bar, 2 door handle, 3 lower area AND when I get home I'll also look into the top 2 LEDs in the ceiling panel that fire down that have the ability to change color as well, depending on color pattern, which could be coded as a higher Layer. - After you select the color desired just code and that's it Update: Currently on Software 002.255.073, Just checked BMW.com and 003.255.081 is available, contemplating upgrading not sure if I some codes will get relegated.. Update2: Nothing changed after update, all coding as is. I can confirm this steering wheel heater code works as well. Last edited by maDjzo; 03-17-2019 at 04:35 PM.. |
4
03-16-2019, 11:13 AM | #1176 | |||
Rep 1,343
03-16-2019, 11:16 AM | #1177 | ||||
Rep 885
03-16-2019, 11:36 AM | #1178 | |||||
Rep 1,343
03-16-2019, 11:45 AM | #1179 |
Rep 1,343
When I sent my screenshot to the developer he said it looked like mapping was missing. He said he was going to look into it. Haven't heard anything yet.
03-19-2019, 10:15 AM | #1180 | |||||
Rep 1,343
03-19-2019, 12:15 PM | #1181 | ||||||
Rep 885
03-19-2019, 12:17 PM | #1182 | |||||||
Rep 1,343
03-19-2019, 07:36 PM | #1184 | ||||||||
Rep 7,159
Russmov1328.00 |
03-20-2019, 03:53 AM | #1185 |
231
Rep 369
Finally I received VeePeek BT and it works perfectly with iOS, not a single issue so far.
I have managed to code few things: Driver seat belt warning disabled Handle light with reverse Fog lights with high beam Seat belt reminder after start disabled Tails gate open and close from remote Angel lights 100% brightness with parking lights Angel lights 100% brightness with low beam VLD Variable Light Distribution Tire pressure and temperature Cameras legal disclaimer disabled Fog lights with parking light Cornering lights disabled Video in motion I couldn't code 5 blinks, ambient light and indicators in HUD
Current
2018 F15 M sport x35i Past 2017 GMC Sierra Denali 2017 GMC Yukon Denali 2016 GMC Yukon SLT 2015 GMC Sierra All Terrain |
03-23-2019, 12:46 AM | #1186 |
231
Rep 369
VLD Variable Light Distribution on my Xenon lights works excellent
Still can't get ambient lights to work
Current
03-23-2019, 12:43 PM | #1187 |
Rep 885
03-23-2019, 03:20 PM | #1188 |
231
Rep 369
O yeah, lights are moving around like crazy now. It's pleasure to drive at night
Current
maDjzo861.50 |
