06-23-2014, 07:34 AM | #1 |
Rep 454
35d, x-line, launch control?
Flame suit on... Maybe this had been discussed.... But as far as I know only the M-sports have launch control. However, yesterday just to see how it would do I came to a stoplight, where Id be accelerating onto a freeway on-ramp... Put the car in Sport and the transmission in sport so that "S1", first gear, showed on the display.
Light turned green and I quickly took my foot off the brake and floored the accelerator. It did not instantly take off... Instead there was a momentary delay, the revs shot up, and then it bolted off the line. It was quick enough that it startled me and I lifted. I repeated the procedure again just to see, and same thing.... I can't figure out if it's a launch program or if the car knows full throttle will overwhelm the tires so it's some part of the traction control. Either way it's awesome.
Ride: 2020 F87 M2C, 6MT Drive: Nine-Four Motorsports
Before: 2013 - 3.8L GTR, first DCT 2012 - 5.2L R8 v10, 6MT 2011 - 4.0L E92 M3, 6MT |
06-23-2014, 08:33 AM | #2 | |
Rep 450
Glad you like it, hopefully I'll be able to try mine out soon. |
06-23-2014, 10:21 AM | #4 |
Rep 450
06-23-2014, 02:26 PM | #5 |
Rep 20
I'm sure its only available in M versions.Here is the cut from the manual
Press button or select with the Driving Dynamics Control Sport+. TRACTION is displayed in the instrument cluster and the indicator lamp for DSC OFF lights up. 2. Engaging the transmission position S 3. With the left foot, forcefully press down on the brake. 4. Press and hold down the accelerator pedal beyond the resistance point at the full throttle position. A flag symbol appears in the instrument cluster. 5. The starting engine speed adjusts. Within 3 seconds, release the brake. So looks like no Flag no Launch
2014 X5 XDrive 35i
06-23-2014, 02:45 PM | #6 | |
Rep 196
Maybe your transmission is slipping? |
06-23-2014, 02:54 PM | #7 |
Rep 454
Thanks for the replies. It seems like it's a pretty deliberate launch from the transmission. Def no flags on the dashboard...
Will try to make a GoPro of the launch |
06-24-2014, 07:37 AM | #8 |
Rep 106
Ag64 is correct. Launch is engaged once you see a flag on dash. This is exclusive of the M sport versions.
_____________
2014 X5 30d M 2011 335d 2012 Grand Cherokee (sold!) 2003 MB SLK stick (garage queen) |
