06-27-2014, 04:34 PM | #1 |
Rep 14
Winter wheel/tires for '14X5 5.0 M-sport
Just curious what people are running for a winter wheel/tire setup... Tirerack claims they have nothing that will work on a 5.0 because of bigger bakes??? I'm a little confused by this because it seems to me the same wheel options are shared across all x5 drivetrain options. I'd like a 19-20" set with run-flats. Any guidance would be appreciated!
06-27-2014, 06:19 PM | #2 |
Rep 609
Hi U55, I had the same questions until I did some research. Here are some options.....
http://www.pirelli.com/tire/us/en/ca...rsionId=437693 http://toyotires.com/tire/pattern/ob...r-tires?cat=12 I ordered the toyo tires for my 20" 451 wheels, I'll update when winter comes around. Joe |
06-27-2014, 07:02 PM | #3 |
Rep 110
Drives: 2024 X5 M60i
I was told the same thing by a few people about the brakes. However after going to my local place and testing the same rims that worked on the prior model works on the f15 or at lest seamed to.
Decided to put continental DWS on oem wheels. Worked well. |
06-29-2014, 06:38 AM | #5 | |
Rep 110
06-29-2014, 11:56 AM | #6 |
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
The stock 19's on the X5 are 255/55/19. Those are the same size tires that I have for my winter setup for the wife's x5. It may be difficult to find 20" winters but I have read people have them
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
06-29-2014, 07:35 PM | #7 |
Rep 1,417
19 RFT Nokian. Hakka R2.
http://www.tirefactory.net/HakkapeliittaR2.htm http://www.nokiantyres.com/winter-ty...kapeliitta-r2/ The invented the snow tire. |
06-30-2014, 09:42 AM | #8 | |
Rep 774
http://f15.bimmerpost.com/forums/sho...=winter+wheels |
06-30-2014, 11:15 AM | #9 |
Rep 3,307
I'll be using the stock 19's (467m). Fairly easy to find run flat snows that size. I don't see why they would have an issue with the wheels, as the 50i comes with the same 19's as the 35i lines do. Only difference I've seen is the no line has different 18's on the 50 vs 35, but presumably still same size. So I call BS on the brake issue...
