      03-07-2019, 06:15 PM   #1
Yardi78
Yardi78's Avatar
Drives: 2019 X5 Xdrive50
X5 with 437m wheels
Hey guys. I got a set of wheels for my f80 and wanted to know if anyone fit the 437m wheels on an F15? Any help is appreciated.
      03-18-2019, 02:36 PM   #2
PhotoGuy87
PhotoGuy87's Avatar
97
Drives: 11 M-Sport 335d, 11 E91 328i
I'd be interested in seeing how this would look as well. The 437m wheels are definitely one of my favorite wheels from BMW.
      03-18-2019, 02:46 PM   #3
mikeson
mikeson's Avatar
Drives: 2016 X6 M package
That looks like 623M wheel which OEM x6 wheel.
      03-18-2019, 02:52 PM   #4
gqgambler
gqgambler's Avatar
Drives: Fast & Furious
F80 bore I believe is 72.6 vs the F15 which is 74.1
      03-18-2019, 03:19 PM   #5
Qsilver7
Qsilver7's Avatar
Not having the actual specs of the 437 wheels...if their wheel offset range is lower than the average f15 wheel offset range...then the wheels are going to stick further out (poke). And the wheel's hubs will need to be bored out (as already mentioned) since they are smaller (72.56mm) vs the 74.1mm wheel hub that the f15 X5's have.
If you want to bore the wheel hubs out so that they will fit...then I'd run their specs through a wheel/tire size calculator so that you'll know how much "poke" you'll have and also make sure that it doesn't rub any suspension parts. I recommend inputting your original...then the new wheel & tire sizes though the calculator at this site: www.willtheyfit.com And you'll also probably need to change the tire size to match what is recommended for the X5...I doubt the f80 3 series uses a tire with the same aspect ratio as the X5 do to weight and other physical dynamics.
      03-18-2019, 03:57 PM   #6
CT335xi
CT335xi's Avatar
683
Since the 437 comes on the F80 would they be strong enough for the x5 weight/ cargo load?
2022 x5 m50i - Dravit grey
2014 x5 50i msport
      03-18-2019, 05:04 PM   #7
Qsilver7
Qsilver7's Avatar
That would be something definitely to consider...do f80 wheels have enough load rating to use on an X5?
      03-18-2019, 08:00 PM   #8
1norseman
Drives: X5 50i
If you compare the weight of each rim, I'm thinking no they won't be strong enough.
There is about 30% more material in the X5 rims.
If that weight is in the hub and spokes, the X5 rims are likely way stronger than the F80 rims.
Style 437 specs:
9x19___255/35R19__ET 29__10,40kgs
10x19__275/35R19__ET 40__10,60kgs
Style 447 for the F15 Specs:
9x19___255/50R19__ET 48__15,39kgs
10x19__285/45R19__ET 53__15,76kgs
Search this Thread:
Advanced Search
