03-18-2019, 12:14 AM | #1 |
Rep 169
OEm trailer harness
I am about to order a hitch 2” for bikes and also the ability to put different height ball attachments. Looking online and extended searches it looks like I have to buy BMW only harness. Is this plug and play or does it require a bunch of cutting. Thanks.
03-18-2019, 07:23 AM | #2 |
Rep 234
It will require a trailer module and coding. However if you only want to use for bike racks then you really don’t need to get the module and wire harness.
Trailer module part number: 71-60-6-889-589 Wire harness part number: 82-71-2-349-500 |
03-18-2019, 07:57 AM | #3 |
78
Rep 116
Garage List 1993 BMW 525iT [0.00]
1989 BMW 325iX [0.00] 2015 BMW 335i M-Sport [0.00] 2007 BMW X3 M-Sport [0.00] 2015 BMW X5 [0.00] |
Zero cutting, but not directly plug and play per sey either. I'd recommend reading through this thread...
https://f15.bimmerpost.com/forums/sh....php?t=1508166 If you need coding help, drop me a line. |
03-18-2019, 10:28 AM | #4 |
Rep 169
I would be pulling the odd utility trailer so lights would be needed. But I don’t mind if when I’m in reverse it beeps a little and I don’t need the camera zoom.
03-18-2019, 11:53 AM | #5 |
Rep 7,154
That's all the coding is for. Just plugging in the harness it will auto detect and work. But coding is mostly for hitch zoom and maybe one other non needed feature. Not sure if the brake controller needs coding but not needed for a little utility trailer.
03-18-2019, 12:09 PM | #6 |
Rep 276
Do I still need both of these if I have the "trailer coupling" option?
03-19-2019, 10:33 AM | #7 |
Rep 234
I am not sure what the trailer coupling option is. Do you already have the hitch cross tube installed? If so do you have the receptacle? You can also check inside the fuse box to see if you have the module.
03-20-2019, 09:07 AM | #9 |
1148
Rep 2,426
If you don't code, I don't think the brake lights will work...
2015 BMW X5 xDrive50i
BMW CCA 509766 |
03-20-2019, 05:48 PM | #10 | |
Rep 7,154
