      02-28-2019, 12:29 AM   #45
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Originally Posted by Cbozz View Post
I asked them and bracket alone is $350, then I also compared the OEM porsche caliper to the one they sell and the mounting part is shaved down.... so if you add it all... 350+about 400 for calipers that's 750... then they charge 850 for machining them down and powder coating but only gold and blue..
here are the difference i noticed - seems like the trim very little of it
What Porsche is that caliper from? I just cant justify $1600+ for this, i'd rather do it myself, brackets are not that difficult to make...
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      02-28-2019, 08:30 AM   #46
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Panamera.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      02-28-2019, 08:31 AM   #47
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Originally Posted by Ehloo View Post
I might do this. Do they sell pads also. So assuming stock rear rotors would work
Yes these are designed to work with oem F85 rear rotors.
'06 C55 AMG (sold)
      02-28-2019, 09:15 AM   #48
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
has anyone looked into taking the front brembo calipers from the e70 x5m or from the f15/f16 mpbk kit and installing in the rear? they're already blue, they're ready from box in terms of seals etc. and the "kit" is priced very well from the dealer or online.
      02-28-2019, 12:27 PM   #49
Cbozz
Cbozz's Avatar
Drives: M3
aren't those 6 piston? with this swap I read that most important thing is to keep the piston sizes as close to original size of single piston OEM caliper due to brake bias and all that... you don't want to have too much grip in the rear because it will throw it all off... I guess cayenne is as closest in size and weight to X5m..
      02-28-2019, 12:28 PM   #50
Cbozz
Cbozz's Avatar
Drives: M3
you can probably grind it down yourself or just have a shop mill if down flat -- that shouldn't be expensive not 1k worth ...
      02-28-2019, 12:31 PM   #51
0-60Motorsports
Bahrain
792
you can probably grind it down yourself or just have a shop mill if down flat -- that shouldn't be expensive now 1k worth ...
Yeah exactly, easy to do it myself. I might attempt this when it comes to changing my rotors
Current Mods:
IG: @060Motorsports
      02-28-2019, 12:38 PM   #52
iconoclast
iconoclast's Avatar
7266
Nope. The F15/F16 MPBK is four piston. I installed them on mine back in the day. The E70 X5M is also four piston.
F15/F16 MBPK 34112348054:
E70 X5M 34117847241:
      02-28-2019, 02:22 PM   #53
Cbozz
Cbozz's Avatar
Drives: M3
keep us posted on here!
      02-28-2019, 02:23 PM   #54
Cbozz
Cbozz's Avatar
Drives: M3
only difference is that this rotor is so much bigger so may not work for the rear...
I'd be curious to se someone get that fitted on the rear rotor
      02-28-2019, 02:27 PM   #55
iconoclast
iconoclast's Avatar
7266
if it is the same size caliper i am sure it will not have an issue when mounted with the bracket but don't know for certain. i installed x5m rear rotors on my f15 and they were larger. i did not have any issue.
      02-28-2019, 02:33 PM   #56
0-60Motorsports
Bahrain
792
Of course bud. Always.
Current Mods:
IG: @060Motorsports
      02-28-2019, 03:16 PM   #57
iconoclast
iconoclast's Avatar
7266
Tronik on BP commenting on the brakes and their kits:
https://f15.bimmerpost.com/forums/sh....php?t=1450854
https://f15.bimmerpost.com/forums/sh....php?t=1449075
      03-01-2019, 05:23 PM   #58
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
It's not the same size caliper. And the rotor is 10mm smaller (395-385) and 12 mm thinner (36-24).
I've heard of one example but I don't think it's ideal. I mean I guess you could just put the front rotors on the rear as well. With a new hear shield.
'06 C55 AMG (sold)
iconoclast7265.50
      03-01-2019, 08:20 PM   #59
iconoclast
iconoclast's Avatar
7266
what is the size of the rear f85 rotor? perhaps that could work with the front e70 x5m caliper.
      03-02-2019, 06:23 AM   #60
fr_tz
fr_tz's Avatar
Drives: F90/G05 50e
2024 G05 50e  [9.50]
34-21-2-284-904/903 - Rear Passenger Disc Brake Rotor Genuine BMW
385 X 24 mm
iconoclast7265.50
      03-02-2019, 06:39 AM   #61
fr_tz
fr_tz's Avatar
Drives: F90/G05 50e
2024 G05 50e  [9.50]
Here's my 4 piston kit from Tronik. It's a used caliper set left unfinished as I'll be powdercoating my fronts and want to do them together/match.
The set that he sells on eBay for $1600 are actually new calipers that have been modified. You can go the used route with him to save a little. Beyond the calipers indeed being shaved down at their mounting post, the adapters, there's also two metal plates that the pads adhere too. This is to accommodate for the thinness of the 24mm rotors.
I also worked out a deal to include SS lines all round and got Front adapters for my 6 piston M5 fronts. PM me for any questions.
Maverik2594140.00
iconoclast7265.50
Cbozz688.50
      03-02-2019, 10:39 AM   #62
pk9394
Drives: X5M
      03-03-2019, 12:55 PM   #63
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Just talked to them today. Found it they no longer use panamera but use Touareg cuz they're cheaper. Can't help but notice the price hasn't changed since they made the switch lol. Need to find someone local that can mill these to spec.
You think you can take some measurements of how much they shaved them down?
'06 C55 AMG (sold)
      03-03-2019, 03:18 PM   #64
iconoclast
iconoclast's Avatar
7266
Touareg is what ECS has used for almost decade on their in-house BBK. Others have sourced used 996 calipers which most often have to be rebuilt and repainted.
      03-03-2019, 04:24 PM   #65
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Ya nothing wrong with it. Just different than what they originally said they were using before they got banned.
'06 C55 AMG (sold)
iconoclast7265.50
      03-10-2019, 10:36 PM   #66
Cbozz
Cbozz's Avatar
Drives: M3
Can you post pictures of those metal plates that go behind the brake pads?
Can you also measure how thick they are?
Lastly can you post a review of that kit and how it feels when you drive?
I know this is asking a lot but thanks in advance!! I'm sure a lot of us will appreciate this!
