03-04-2019, 09:01 AM | #1 |
Self-Deprecating Narcissist
7266
Rep 6,561
2018 X5M Anti-Dazzle / Auto-Dimming Mirrors...
Are all 2018 X5M equipped with only Driver's side dimming only? Is the second mirror part of another package or just removed from 2018?
03-04-2019, 05:37 PM | #2 |
569
Rep 380
03-04-2019, 08:02 PM | #3 |
7266
Rep 6,561
Peculiar. Same here except without NVA and RSE but I doubt either would effect auto-dimming mirrors. On mine the Driver's side and the interior mirror dim. The Passenger does not. It does not have a dimming mirror or the plug behind it (unless tucked behind motor).
03-05-2019, 11:16 AM | #4 | |
OEM CSL Whore
1250
Rep 1,476
Here is the passenger side mirror. |
03-05-2019, 12:33 PM | #5 |
7266
Rep 6,561
I noticed it when pulling it into the garage for the first time. At first I thought it was a faulty mirror then when I looked at the mirror it did not have the wire running along the perimeter of the reflective side. Pulled it off and it looks just like yours. I have a set of Euro Anti-Dazzle electrochromatic mirrors and installed them as well but now the question is... Retrofit?
03-05-2019, 07:17 PM | #6 | |
Rep 108
03-05-2019, 08:47 PM | #7 |
7266
Rep 6,561
On the E63 it involves running the wire with the connector to the driver's side connection so they run in tandem. On Audi it is more detailed and you need to swap door modules and other bits. No idea what it would entail on the F15/F85 and first I am even noticing it and seems most others on here were just as surprised as I am.
CanadianLurker41.00 |
03-05-2019, 09:07 PM | #8 | |
OEM CSL Whore
1250
Rep 1,476
03-06-2019, 06:52 AM | #9 |
7266
Rep 6,561
on the 2017 X5M i had all three dimmed together. i am guessing no more than a charge is required to activate the deviation in color but if it is like the E63 then it can be done just like that. in my head the path of least resistance was to run the wire through the engine bay and back in through the pillar as opposed to removing a dashboard. thoughts?
03-06-2019, 10:58 AM | #10 | |
OEM CSL Whore
1250
Rep 1,476
But, I'm thinking the signal on the passenger side mirror may already be there. It may just need to extend it to the mirror and or just add a connector. We need to access some f85 wire diagrams. Where can we get these ? |
03-06-2019, 12:26 PM | #11 |
7266
Rep 6,561
No idea. Perhaps there is a BMW Tech on here or someone who has access to ETKA.
03-13-2019, 12:51 PM | #12 |
7266
Rep 6,561
let the games begin:
03-13-2019, 02:37 PM | #14 |
7266
Rep 6,561
I could not find the P/N alone on ETKA/ELSA and started browsing. I stumbled across a seller on eBay. Still need a plan but at least I have the parts.
Gatoferoz251286.00 |
03-14-2019, 09:47 AM | #15 | |
Rep 7,470
If you need wiring diagrams...you can get them at the online BMW TIS website: https://www.newtis.info/ Just type the last 7 digits of your VIN (or select accordingly if you don't know it)...this will take you to a page that you can look manually...or you can type a keyword or phrase in the search box. In this case, I would type "electrochromic side mirror" or "electric outside mirror" and see what you get. The links with SSP are actual wiring diagram links...and within the schematic...if you see colored text...those are additional links that will supply more information. EDIT: Info below is an exert from the following link that explains the auto dimming of the exterior side mirror: https://www.newtis.info/tisv2/a/en/f...ics/1Vnc8Gi5aS
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-14-2019 at 10:00 AM.. |
6
03-14-2019, 11:06 AM | #16 | ||
OEM CSL Whore
1250
Rep 1,476
03-14-2019, 03:40 PM | #17 |
7266
Rep 6,561
I suspect you would have to enter the vin of a 2017 or earlier model since 2018 would not have the wiring for the passenger side. Correct?
03-14-2019, 05:12 PM | #18 |
Rep 1,061
It would appear to me that this is a manufacturing defect or error in the harness. There is a connector for the mirror dimming/camera/adjustment just behind the tweeter in the corner of the door where the mirror mounts.
I am hopeful for you that it is just the mirror portion of the harness that is missing and you can stop wiring there. It is possible to add wiring to the door harness as well but this is also split at the door jamb and you are going to need additional connectors/pins to make this work correctly and keep things watertight. After thinking this through more, I would remove the tweeter / trim (look for a bavsound video of how to do this) and see what wiring runs to this plug. If the wiring is all there, it makes your fix much easier as it's only the mirror wiring that is missing. See pictures below: Last edited by ferrarif1; 03-14-2019 at 05:26 PM.. |
iconoclast7265.50 CanadianLurker41.00 |
03-15-2019, 07:31 AM | #19 |
7266
Rep 6,561
Do believe that if I purchase a 2017 X5M passenger side mirror all components may be there?
03-15-2019, 11:16 AM | #20 | |
Rep 1,061
I am assuming that you have asked your dealer about this. I can't think of why BMW would make this change for 2018 and would push the dealer to fix things before you tear your car apart. |
iconoclast7265.50 |
03-15-2019, 01:29 PM | #21 |
Rep 1,844
This is very strange. I sold Daytona the mirrors that I used on my 2016 X5M. That model year both F15 and F85 had autodimmjng mirrors on both sides. Hard to imagine that this saves BMW enough money to make the change. I'm hoping for you guys that the wire is in the connector for the mirror.
03-15-2019, 02:20 PM | #22 |
7266
Rep 6,561
the '16 and '17 i owned both had it. '18 does not.
