03-16-2019, 04:40 PM | #23 |
Rep 108
Subscribed to see how things go. I've found a used euro-spec mirror that I'm going to buy. Worst case, I'll get the benefit of the wider angle blind spot mirror and best case case I'll be able to get the dimming to work too!
iconoclast7262.50 |
03-18-2019, 03:47 PM | #24 |
Rep 7,449
You can see in the pics below what the wiring harness looks like for the "F" series BMWs that have EC (auto dimming) side view mirrors:
03-18-2019, 06:32 PM | #25 |
Self-Deprecating Narcissist
7263
Rep 6,561
if i recall correctly that is what it looked like on my f31... on f15/f85 it should look like this:
03-18-2019, 06:53 PM | #26 |
Rep 108
03-18-2019, 06:56 PM | #27 |
7263
Rep 6,561
CanadianLurker41.00 |
03-26-2019, 10:43 AM | #28 | |
Rep 108
Staying tuned to see what's involved in the retrofit! |
iconoclast7262.50 |
04-24-2019, 08:01 AM | #29 |
7263
Rep 6,561
Found it easier to code the auto-dimming exterior mirrors off for the sake of symmetry than figuring out a way to enable the passenger side. If anyone on here has better luck or success getting this going please post.
04-25-2019, 05:12 PM | #30 | |
Rep 7,159
Weird they stopped putting these in F15/85
04-25-2019, 07:05 PM | #31 |
7263
Rep 6,561
i have tinted windows so it isn't that helpful but i was more interested having it match than the option itself.
06-04-2019, 07:56 PM | #32 | |
Rep 108
Sadly, got hit in a parking lot by somebody backing out without looking. As a result the passenger door needs to get stripped down,?repaired, and repainted. This means the body shop has to take off the side mirror and trim. Is there something that I should have them look at when they get it off? Or something that I should ask them to do while things are apart? Wondering if it'd be worth while to see about getting it at least partially wired up while it's all apart? ie make the connection at the mirror and run the wiring though the door and leave it as an open end in the passenger footwell where I could pick it up and finish the job later? Hoping to put a positive spin on a negative event by getting this missing feature added! |
06-06-2019, 08:59 PM | #33 | ||
Rep 1,061
The majority of wiring this is done by removing the interior door card so refinishing the outside does not buy you much. |
06-06-2019, 09:00 PM | #34 | ||
Rep 1,061
Blank
07-08-2019, 06:44 PM | #35 | |||
Rep 108
05-08-2022, 02:50 AM | #36 |
Rep 1,346
I am about to do this DIY and will later on make a post about it. What it needs is Mirror Electronic to activate the dimming on Passenger side. Some buys Mirror assemly that came out from 15-16 F85 which includes this module already in it and when you swap the entire unit, it works without coding or additional cabling.
Or you buy the Mirror Electronic, depending on your options like 360 camera / lane assist. then swap the inside part with the one comes with electrochromic and you are good to go
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
X Driver70.00 iconoclast7262.50 |
09-21-2022, 08:30 PM | #37 |
Rep 1,346
Hello folks. As i promised i have done the swap on my F85 with a unit that came out from G01 X3. But it did not work. I believe G series Lin bus or the Mirror Module SW working different than F series. Lane warning light flashed couple times after installation but nothing was working. I will sort out the F series soon and will be done with it.
iconoclast7262.50 |
10-07-2022, 05:36 PM | #39 |
7263
Rep 6,561
Correct. 2018+ Do not have it.
10-16-2022, 08:12 AM | #40 |
Rep 105
iconoclast7262.50 |
10-16-2022, 08:17 AM | #41 |
7263
Rep 6,561
I would rather not have it all than have it only on one side. It is the one thing that annoys me the most on the E63.
10-18-2022, 01:14 AM | #42 |
Right to Repair Enthusiast
93
Rep 115
Just picked up a '17 built in February of 2017, no passenger side electrochromic mirror. Very, very bizarre choice considering my plebeian Grand Cherokee had it on both sides and cost about $65k less original MSRP.
10-18-2022, 10:32 PM | #43 |
Rep 900
While replacing the cracked passenger-side supporting ring of the side mirror, took a couple of pics of the electrochromic connectors on my 2015 X6M. The first pic shows the white male electrochromic connector on the mirror itself. The second pic shows the female white connector for electrochromic and the two black wires for the mirror heating element. Those two black wires connect to the two male connectors right below the electrochromic in the first pic.
10-19-2022, 05:06 PM | #44 |
Rep 1,346
Alright folks, retrofit done successfully. I got a broken F26 X4 mirror with all options. Removed the lin bus module and swap with mine. Everything is working. I will swap to Euro mirrors and done with this.
https://youtube.com/shorts/njZsAB6kJbk?feature=share
musa421.50 iconoclast7262.50 |
