      03-06-2019, 09:26 PM   #1
LastLong
LastLong's Avatar
Drives: Nothing
wheel center bore of F15/F16
Hi,
I whould like to know what is the size of the center bore of X5 (F15) and X6 (F16) of front and rear wheels?
On the X5 (E70) is:
-Front 74.1 mm
-Rear 74.1 mm
On the X6 (E71) is:
-Front 74.1 mm
-Rear 72.56 mm
Is the same thing on the new X5 and X6 ?
Thank you !
- 2015 F85 BMW X5M = SOLD
- 2012 E70 BMW X5 35i - M Sport = SOLD
- 2008 E71 BMW X6 35i - Sport Pack = SOLD
- 2007 E70 BMW X5 4.8i - Sport Pack = SOLD
- 2007 E70 BMW X5 30si - Sport Pack = SOLD
      03-06-2019, 10:42 PM   #2
F15 X5, F16 X6, F85 X5M, F86 X6M are 74.1mm.
PM for Everyday DEALS!!
      03-07-2019, 08:24 AM   #3
LastLong
LastLong's Avatar
Drives: Nothing
Nice, so no one has 72.56mm for the rear like the E71 X6/X6M and E70 X5M.
Thank you !
      03-07-2019, 09:13 AM   #4
Thank you !
Only E71 X6/X6M and E70 X5M.
      03-07-2019, 09:55 AM   #5
bagekko
bagekko's Avatar
Drives: Lots of BMWs
2018 M4 Vert  [0.00]
2006 Z4M Roadster  [0.00]
1995 540i  [0.00]
2008 BMW M5  [0.00]
2019 i3 Rex  [0.00]
2021 X7 40i MSport  [0.00]
Sucks that the new G05 X5, G30 5er, G01 X3 and G07 X7, are now 66.6mm Hub and 5x112 bolt pattern. Dont know about the new G20 3er, but I assume all BMWs are moving to the new sizes. OEM wheels in the new sizes aint going to be cheap and the older 74.1/72.5mm 5x120 wheels will plummet in price.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX
2021 X7 40i MSport, 2006 Z4M 6spd
      03-07-2019, 01:53 PM   #6
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1250
Drives: 2017 F85 X5M
i thought the f85 had different hub sizes as h&r provides different spacers
      03-07-2019, 03:15 PM   #7
Nope.
      03-07-2019, 04:31 PM   #8
daytonaviolet
OEM CSL Whore
Philippines
1250
Nope.
then why do i have two sets of 15mm spacers form h&r with different part numbers?
      03-07-2019, 05:29 PM   #9
Nope.
Early production F15 uses same hub with E70.
Different hub height. CB still the same.
      03-07-2019, 05:57 PM   #10
F1 fan
Drives: 2008 e92 m3 all options. Sold
On this topic. Most aftermarket wheels that are not hub centric are use a smaller centerbore than 74.1 correct. I assume that is why the wheel selection is low for the x5.
      03-18-2019, 08:52 AM   #11
LastLong
LastLong's Avatar
Drives: Nothing
Is 74.1mm rear rims from a X5 can fit on X5M/X6M (E70/E71) with smaller rear center bore?
Can they fit without center hub ring ?
      03-18-2019, 09:29 AM   #12
They can fit, but best to use hub ring.
      03-18-2019, 11:58 AM   #13
LastLong
LastLong's Avatar
Drives: Nothing
Good, do you know where can I get a set of good hub ring?
I tried to find, but I am not sure....
Thanks !
      03-18-2019, 11:59 AM   #14
Thanks !
Amazon should have it.
      03-25-2019, 08:33 AM   #15
LastLong
LastLong's Avatar
Drives: Nothing
Thank you ! Just got it !
