03-18-2019, 03:19 PM | #5 | |
Rep 7,452
If you want to bore the wheel hubs out so that they will fit...then I'd run their specs through a wheel/tire size calculator so that you'll know how much "poke" you'll have and also make sure that it doesn't rub any suspension parts. I recommend inputting your original...then the new wheel & tire sizes though the calculator at this site: www.willtheyfit.com And you'll also probably need to change the tire size to match what is recommended for the X5...I doubt the f80 3 series uses a tire with the same aspect ratio as the X5 do to weight and other physical dynamics.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-18-2019 at 03:24 PM.. |
201198.50 |
03-18-2019, 03:57 PM | #6 |
Rep 1,434
Since the 437 comes on the F80 would they be strong enough for the x5 weight/ cargo load?
2022 x5 m50i - Dravit grey
03-18-2019, 05:04 PM | #7 |
Rep 7,452
That would be something definitely to consider...do f80 wheels have enough load rating to use on an X5?
03-18-2019, 08:00 PM | #8 | ||
Rep 648
There is about 30% more material in the X5 rims. If that weight is in the hub and spokes, the X5 rims are likely way stronger than the F80 rims. Style 437 specs: 9x19___255/35R19__ET 29__10,40kgs 10x19__275/35R19__ET 40__10,60kgs Style 447 for the F15 Specs: 9x19___255/50R19__ET 48__15,39kgs 10x19__285/45R19__ET 53__15,76kgs |
