03-01-2023, 10:19 AM | #1 |
Rep 8
Crank shaft bearing failure Canada class action
Correction - Rod Bearings
Has anyone in Canada had premature wear or failure of the rod bearings? It’s mostly V8 engines. In most counties BMW is fixing the problem, in Canada they are only if you have warranty and your car is still worth more than the fix. Bmw should at least add rod bearing replacement to the suggested 100,000km service. Last edited by Rhondax5m; 03-01-2023 at 06:04 PM.. |
03-01-2023, 05:44 PM | #3 |
Rep 8
